Go Back   VZi, Europe's largest VW forum, community and sales > Tech Forums > Aircooled Mechanical Tech
Aircooled Mechanical Tech A Q & A Forum devoted to Aircooled Mechanical Issues. Got a problem? Then ask in here. Please, no 'For Sale' or 'Want To Buy' ads, plugs for your 'business', links to 'for sale' ads or Ebay links to your (or your mate's) auction (use the VZi 'Classifieds' section) - this also includes thinly veiled 'What's My Car Worth?' threads and "Who Can Sell Me A . . ." posts.Forum sponsored by www.machinemart.co.uk
Machine Mart
Old 14-06-2004, 09:58 AM   #1
jblackmore
jblackmore's Avatar
Default How we fitted JK Hinged RockNRoll bed into a split bus
Some notes on this and some pics (taken by me, but if anyone wants to copy them then go ahead), in case this is useful to anyone planning to do this.
Basically the JustKampers R&R bed hinges are superb, and I think fantastic value for money.
We knocked out the bed from 18mm ply in about 3 hours, and we are pretty hopeless, so if we can manage this anyone can. There is still a bit of finishing but I would think if we had got on with this two people could have completed it easily in a day.
The main fiddly bit was the endplates for a split which are a different size to the bay diagram JK sent me (but I knew it would be) - I made a cardboard template and will put the dimensions up on here sometime, or if anyone wants them shout. The front panel was a bit taller also.
Seat back and base are depths as per JK diagram, but width was measured once the other bits were done, as I wanted a full width bed but didn't want the hinges to foul on the interior panels, so made sure there was about 30mm clearance each side.
Bed is not quite finished, I need to fit the support brackets under the seat which sit on the notches in the front panel in bed mode.
Also in bench mode, the base is flexing if you sit in the middle, so I need to add a support at the rear, not sure if I will bolt a length of angle iron between the back of the hinges to support the seat, or if I will cut an 18mm ply rear bulkhead to support it on the top of the wheel arches.
Anyway, pics of the floor/bed going in are below, we did a bit more on Saturday cut some hand holes in the seat to pull it out with, and varnished everything with satin varnish both to look nicer and for some water resistance - I plan to cover the front panel and seat/back edges with vinyl to match the interior panels (I bought 2 yards on a roll from TMI with the interior stuff for this).
jblackmore is offline   Reply With Quote
Old 14-06-2004, 11:04 AM   #2
orb666
orb666's Avatar
Looks great mate, when folded out to become the bed does it sit level with the engine cover?
Orb
orb666 is offline   Reply With Quote
Old 14-06-2004, 12:42 PM   #3
pagey
Looks just what I need for my splittie - if you have any of those dims to hand, plus the final width of the bed that would be really useful -thanks for posting it up!
pagey is offline   Reply With Quote
Old 15-06-2004, 08:52 AM   #4
jblackmore
jblackmore's Avatar
Finished this off last night and bed/bench works great, so some more info:
Its not level with the cover, as the edge of the seat back rests on the cover for strength - you could easily cut it shorter to make it flush, but would have to fit a batton or something else along the ramp of the engine cover to support the 'bed' otherwise it would put a huge strain on the hinges and fixings.
I measured my side panel template again last night and the height is the same as the JK diagram, so the front and top edge and hole positions are all as the diagram, the back edge is to clear the bend in the hinges, as for wheel arches it is easiest to cut the ply exactly as the diagram but on the wheel arch part leave it at least one inch bigger than diagram, then bolt the hinge to the end panel, hold it up to the side of the wheel arch and draw round it with a pencil - I still had to trim it slightly as the wheel arch profile varies along its length on our bus (both sides), but it was close and easy to trim the last bit out.
The way the JK diagram (and I built our bed) is that the side panels are slightly lower than the front panel - I assume this is so the hinges are not strained if they do not quite line up, but I think it would be better if the side panels were the right height to support the base of the seat in bench mode, so I suggest you add 30mm to the height of the end panels (above the holes), and then mark and cut that after you have fitted the hinges and end panels and front panel into your bus, so you can use a straightedge on the hinge in bench mode to mark the exact line. A bit of a faff to then take it all out again to cut but this way I think the bench would be perfect.
If you do get the JK hinges then add 5mm to all the bolt lengths they give you, as otherwise they are not long enough for the nyloc part of the nuts to bite - ie the flat head M6 bolts should be 30mm (diagram says 25mm), and the M8 bolts for the hinges should be 40mm (diagram says 30mm) I would also suggest using M6 penny washers on the inside of the hinge bolts and also on the underside of the brace support bolts.
Also, I didn't cut the top notches in the front panel until the very last thing so I could line the bed up flat and make sure the measurements worked OK, they ended up exactly as the JK diagram though !!
For our full width bed we also screwed a piece of 34mm square batton along the back edge of the bench seat otherwise it sagged in the middle if you sat in the middle - this should also help stop the hinges being pulled together which will wear both the hinges and the mounting holes.
The final width for our bed is 1440mm, but we have TMI interior panels and deliberately left a lot of clearance either side so the hinges don't mark the panels when the bed is going up and down (into a bench not hanky panky). The hinges are outside the bed and have a small peg sticking out to lock in bench mode which I think would mark or tear the vinyl panels if it was close enough to touch them - obvoiusly if you had a wood or carpetted side then you could go a lot closer without worrying.
I don't see why you couldn't get a wider bed in - ignoring the hinges the cargo area is around 1560mm wide for us.
I would assume your bed would be somewhere under 1500mm and wait until you have fitted the side panels, and front, and hinges all where you want them to fit your bus, then measure the final width between the hinges last and make the seat and base then.
Hope this is useful.
James.
Old 15-06-2004, 09:23 AM   #5
orb666
orb666's Avatar
Sounds like you've put a lot of thought and effort into the way that all fits in - well done fella.
Sounds to me like there's a business to be had there fitting them for other people - there are loads of us out there that want a R&R but are mechanically incompetent (like me).
In fact I'm finding it very difficult to find anyone around London who'll build me an interior to my spec (anyone please feel free to butt in and give me loads of people who will )
I've even tried people up North and they're booked up until next year!!!
Hey Ho, I expect I'll find someone who can do it, just need to keep looking.
Orb
Old 15-06-2004, 12:09 PM   #6
jblackmore
jblackmore's Avatar
The bed is really easy, I am completely hopeless, and even had to borrow a jigsaw as I only have a drill and we managed it easily enough with a couple of mates helping on Saturday.
an 8x4 sheet of 18mm plywood is £20 and I needed two for the bed anyway, as I couldn't get the seat back, seat base and front panel out of one sheet, so there was loads of spare wood if we had mucked stuff up - the only difficult bit was the bed side panels which I made out of cardboard first to check the size, and then just drew round on the ply to cut out once sorted.
Also, if your worried about tatty looking edges, I am planning on covering the front panel and the edges of the seat back and base with vinyl, just glue it on and staple round the edges, this will cover up any rough cuts and I hope will look clean and match the rest of the interior.
I had a look at a few interiors people had paid around £4k upwards and frankly I just could not spend that amount of money on something I could have a go at myself. I don't really want a whole side of the bus filled with cupboard units, as half the time we will use the bus as everyday transport so would rather have more seats and space. When we camp we will have an awning anyway for cooking and storage, so it shouldn't be much of an issue.
I don't mind paying people to do welding or bodywork as there is no way i could do it, even if I spent a fortune on tools and premises, but woodwork is pretty easy so I'm sure anyone could do it with a couple of mates to help out.
So far our total spend on our interior is well under £200 that includes the hinges, timber, fixings, carpet and lino. I just ordered all the foam and it was under £100. And reckon another £100 on material for seat covers and curtains. I reckon the split charging system and extra battery will be well under £100, so reckon we will end up having spent well under £500 total for everything.
I don't think you could get a company to do the floor and a bed for that kind of money these days !!
I have heard good things about Calypso Campers in Salisbury (www.calypsocampers.com) but I understand there interiors start from around £3.5k and go up and up and up depending on what you want - thy are normally booked up for months though !.
As with good bodyshops, anyone decent is going to be booked up - frankly if someone could start next week I would run a mile as they must be crap or way too expensive !!
Old 15-06-2004, 02:19 PM   #7
orb666
orb666's Avatar
some very good points there James, I simply don't have the time and even if I did I am one of those people who really, really can't even cut a piece of wood in a straight line (I find it a bit of an embarrassment how crap at practicle stuff like that I am - give me a complex computer storage problem and I'm happy as Larry!)
I have looked at the calypso stuff and although it does look good quality etc there's something about their stuff that I can't quite put my finger on which turns me off.
I, like you, use my bus every day so don't need a cooker or fridge, I just want a full width bed and a seat running along the bulkhead with storage space underneath (but not with the spare wheel showing - creative are doing a frame for that end of the bus similar to the lovely green and white one they did and that covers the wheel housing).
I'm not i too much of a hurry as I have a full Dormobile interior fitted at the moment which is OK but not practical for what we use it for (cooker, sink, storage space etc) so I'll keep looking till i find someone who can do what I want.
Thanks for all your advise on this, nice to see someone passing back info for the masses.
Orb
Old 16-06-2004, 10:02 AM   #8
jblackmore
jblackmore's Avatar
I know what you mean about the Calypso interiors - to be fair most of the 'new' interiors I have seen look too 'modern' I think, as they are all in fancy finishes and plastic trim on every curved edge. I'm sure this is what people want on a moden motorhome interior, but Its not what I would choose for a classic vehicle.
What I think a lot of people want is a 'devon style' finish, ie stained/varnished plywood and nice basic angular interiors, not fancy curved stuff.
I know Mark (www.gingersbuses.co.uk) has been trying to get an interior like this made for a long time, and has found 3 sperate people who said they could do it, but then let him down - dunno if all chippys are lazy, or if they just can't be bothered with 'small' jobs but I reckon there would be a huge market for someone producing simple modular bits for interiors in finished ply, for easy DIY fitting.
Hadn't spent too much time thinking about the bulkhead end just yet, but plan is to make a simple box seat for storage and occasional sitting but the creative frame idea sounds interesting, will have to look out for this, I assume its a metal frame which you just panel with mdf or ply.
As for not being able to cut a straight line, B&Q will cut plywood for you at 50p a cut, I reckon you could get all the panels edge cut square in 5 cuts on each sheet, so for a fiver you would have all the straight cuts accurate and cleanly cut - frankly I wish I'd done this as it would have saved us about 2 hours.
Old 17-06-2004, 11:05 PM   #9
jblackmore
jblackmore's Avatar
Managed to get a lot done this evening, screwed floor down (screws up from underneath), fixed bed frame down to batton on floor, fitted lino in cargo area (laminate wood effect stuff), and Blue carpet over the engine cover. Here are some pics showing the bed up/down and halfway to show the JK hinges working - hope these are helpful to anyone doing this.
Old 18-06-2004, 09:05 AM   #10
orb666
orb666's Avatar
Wow, looking good James - like the idea of screwing the wood from underneath - never thought of that.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SupportingSupporting Brad's Cancer Foundation One of the largest message boards on the web !
