Engine Type 4 head extra holes - VW Forum - VZi, Europe's largest VW, community and sales
Old 20-04-2017, 04:33 PM   #1
21windows
21windows's Avatar
Default Type 4 head extra holes
Hi Guys
I've had a Type 4 1800 engine come in with a load of bits. The engine has been stripped back to a long block and what looks like new heads fitted, but that's as far as they got.
One of the heads appears standard but the other (see picture) has 3 extra holes in it.
1. I think is for a head temperature sender but I have no idea what the 2 and 3 are for, can anyone help.
21windows is offline   Reply With Quote
Old 20-04-2017, 07:32 PM   #2
GARRICK.CLARK+
Those are US spec heads.
Holes are for EGR valves , they go into the exhaust port. You need to tap them and screw a plug into them.
GARRICK.CLARK+ is offline   Reply With Quote
Old 20-04-2017, 09:48 PM   #3
21windows
21windows's Avatar
Excellent thanks for that. I assume i will need to take the head off and remove the exhaust valves to do this will I?
Old 21-04-2017, 02:12 PM   #4
paul_f
paul_f's Avatar
Trading feedback: (4)
M10X1 with 13mm of threads. 46mm of length the the head face. I'd get someone to make you one out of 13mm hex bar
Sent from my A0001 using Tapatalk
paul_f is offline   Reply With Quote
Old 21-04-2017, 06:02 PM   #5
GARRICK.CLARK+
As above.
To do it properly, take the head off. while its off you can have the guides checked to see if there worn. Read up about the valve seats. They can come loose and make a mess to your chambers, piston tops too if your not fast enough to turn it off.
Old 21-04-2017, 06:10 PM   #6
paul_f
paul_f's Avatar
If they are new heads then there isn't any need.
You can get to both sides of the egr ports without taking the heads off, the holes go to the exhaust ports not the chambers
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
