Engine Golf mk2 is dieseling - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Tech Forums > Watercooled Mechanical Tech
Old 28-12-2016, 09:14 PM   #1
adman020
adman020's Avatar
Default Golf mk2 is dieseling
For the last month the wifes mk2 golf 91 1.8 seems to have issues with the carb. On startup idle speed instead of 10k rpm shoots up to 25/30k rpm, it does not go back to normal when the engine has warmed up.
Plus the fun one...
when the ignition is switched off the engine will fight with itself for up to 2 minutes afterwards (getting lots of looks from people).
It is intermittent as half the time the problem does not happen.
I was going to start off with finding an airleak, checking rotor arm, dizzy cap etc.
But is this a normal issue?? and thought that it was something to do with the choke betting stuck as it's an intermittent issue? Any advice would be appreciated
adman020 is offline   Reply With Quote
Old 10-01-2017, 09:33 PM   #2
adman020
adman020's Avatar
Okay have checked rotor, dizzy cap, lubricated throttle cable and the golf is still coming to life after the ignition is switched off.
Here's a video of what happens.
http://v9.tinypic.com/player.swf?file=242vn6r&s=9
Next I was going to check the timing but anything else I should check for??
Old 10-01-2017, 09:59 PM   #3
rowlesy
rowlesy's Avatar
"run on" is usually timing or vacuum leaks. but the pierburg carb will do that for you also! air leaks have a massive affect on the carb so check all pipes! then try wiggle the carb around to see if the base adaptors split. my last golf raced away when cold but ticked over fast when warm. i few perished pipes on the n/s was the culprit
rowlesy is offline   Reply With Quote
Old 11-01-2017, 09:43 AM   #4
xenon
Default golf
wax stat on carb , common prob
xenon is offline   Reply With Quote
Old 11-01-2017, 05:22 PM   #5
lambretta lee
Get a Weber conversion , mine ran well with it
lambretta lee is offline   Reply With Quote
dieseling, golf mk2
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
