Mods move this to tec when its finished please ?
Right then where do i start ?
propex heat sorce >>>>> a gas powered blown air heater..
I purchased a Propex heatsorce 2000 for £350 from ebay recently for the simple fact that i have to pick my kids up in my 69 bay kombi and its my daily so heat is a big issue ... I am sure if you r reading this you know what i mean..
Right then down to business ... When you buy one of these heaters it comes with everything you need to fit it into your van so dont worry as long as you order a vehical kit you will get the basics of what you need out of the box with full fitting instructions ..
And this is whet one looks like
the top
The tools r in shot for scale
Underneath
The 2 pipes r the exaust and inlet
This is a list of tools i usedin my instal
Philips Screew driver
Flat head screwdriver
Grinder
drill
30 mm hole saw
75mm hole saw
center punch
marker pen
3mm drill bit
tape mesure
13 mm spaner
zink primer
The above is what is in most peoples shed/garage so if yer dont have these Blag em of some one else
