Adjusting beetle rear suspension - VW Forum - VZi, Europe's largest VW, community and sales
Old 28-08-2007, 10:33 PM   #1
dub_crazee
I really must get out more
dub_crazee's Avatar
Trading feedback: (4)
Default Adjusting beetle rear suspension
it gets asked quite often how to lower a bug or how to raise due to saggy rear end and i needed to adjust mine so here is how i did it - may or maynot be right in everyones eyes but worked for me
this is on an irs set up but similar to swing axle
first - get the wheels off and car on axle stands. on an irs rear end you have to take the wings off as the spring plate extends out due to longer torsion bars
http://img.photobucket.com/albums/v1...e/DSC01166.jpg
remove the shock bolt
http://img.photobucket.com/albums/v1...e/DSC01168.jpg
(similar on swing axle)
mark where the A arm bolts to the spring plate ( or on a swing axle vehicle where the spring plate bolts to the axle tube housing) to make sure it goes back in the smae place. then remove the 19mm bolts and nuts
http://img.photobucket.com/albums/v1...e/DSC01170.jpg
if doing on a swing axle vehicle it is a good idea to pull the axle towards the rear of the car and tie it ip out of the way.
now remove the 17mm bolts on the spring plate cover and lever it off
http://img.photobucket.com/albums/v1...e/DSC01171.jpg
on the irs model you now need to get the spring plate infront of the A arm - lift the a arm as high as it will go and lever the spring plate infront of it ussing a screw driver or similar. be careful at this stage as the spring plate may come off the stop lip and fly downward so keep hands and limbs clear of it.
http://img.photobucket.com/albums/v1...e/DSC01173.jpg
if it hasnt come down you need to lever it off the stop lip using a big screw driver.
now looking at www.bugbabe.co.uk decide how many splines you need to rotate to get the desired adjustment
on a spint axle car you can see the splined torsion bar throught the spring plate- it is a good idea to mark its origional position with tipex.
now pull the spring plate off and rotate on the splines according to the adjustmebnt required.
once done i measure front the spring plate to the floor so i can be sure to get it exactly the same on the other side - but isnt necessarily required)
http://img.photobucket.com/albums/v1...e/DSC01175.jpg
now it is time to reassemble. lift the a arm up and lever it back infront of the spring plate ( not required on SA)
Classic Car Revivals
www.classiccarrevivals.co.uk
Join us on Facebook
http://www.facebook.com/#!/ClassicCarRevivals
dub_crazee is offline
Old 28-08-2007, 10:38 PM   #2
dub_crazee
dub_crazee's Avatar
place the spring plate cover back in place and bolt on losely.
http://img.photobucket.com/albums/v1...e/DSC01178.jpg
place jack under the spring plate and lift up until it is clear of the stop lip. now use a rubber mallet to knock the pring plate fully home on its splinesand make sure the spring plate sits back on the stop lip. now do the bolts up on the spring plate cover - this will stop the spring plate slipping off the stop lip
http://img.photobucket.com/albums/v1...e/DSC01180.jpg
now use the jack to hold the a arm (or axle if swing axle) in the right position and bolt up in place.
http://img.photobucket.com/albums/v1...e/DSC01181.jpg
Do all bolts upto correct torque setting 72 ft / lbs for spring plate i think but please check your manual! and dont forget to bolt up your shock absorber!
wheels back on and you may want to push forward/ back to let suspension settle although it probably wont fully settle until you have driven it.
Join us on Facebook
Old 28-08-2007, 11:19 PM   #3
al_kaholik
al_kaholik's Avatar
VZi Member Sponsor
Trading feedback: (20)
Spring plate compressing tool from VWH will prevent broken fingers/arms/faces *WHACK* how low did your lowering stick make it?
Wasserboxer conversion
'77 Jap import FI and Aircon
al_kaholik is offline
Old 28-08-2007, 11:27 PM   #4
dub_crazee
dub_crazee's Avatar
i was raising it exhaust kept scraping! then i made it too high so lowered it again - tyre now sits about an inch lower than the wing which is good enough for me
havnt heard of that tool but sounds like a fantastic idea anyone used one?
Join us on Facebook
Old 29-08-2007, 02:15 AM   #5
al_kaholik
al_kaholik's Avatar
VZi Member Sponsor
Yup - very simple and effective. I wouldn't contemplate spring plates without one anymore. Right tool for the job and all that.
You wouldn't use a hammer and screwdriver instead of the correct size spanner or socket
Old 29-08-2007, 09:39 AM   #6
Tomarse
Tomarse's Avatar
I've used that tool before and it works fine. However I find that a trolly jack also works fine but is a lot quicker.
Tomarse is offline
Old 29-08-2007, 09:49 AM   #7
magicfiver
PLEASE UPDATE YOUR EMAIL!
magicfiver's Avatar
cool post deano!!
i had to raise mine too cos i made it too low hehe
its also worth noting that on my swingaxle bug, i had to release the handbrake cables (drums off etc)
also make sure your notched rubber bush is seated straight on the torsion beam or the cover plate wont go on
C
My Resto threads - Pt 1, Pt 2
Deutschworks - Volkswagens in Norwich
magicfiver is offline
[IMG] code is Off
