Thought id start fitting the front disc conversion and dropped spindles. picked up the spindles at vw action for 160 from kingfisher kustoms which is cheaper than i've seen them advertised and the porsche pattern disc conversion from machine7.
Unfortunately the adjusters that have been welded in the beam by a previous owner have been welded in the wrong position (unless they wanted to raise the suspension!
) meaning someone had removed the stop bolts and nuts completely to try and get the car as low as they could, which is not that low.
however, with the new dropped spindles/discs and wheels on the tyre was now touching the wing so i had to get the beam adjustable again. I managed to find some bolts and nuts to replace the missing ones in the old man's shed... had to take the spindles and shocks off again to release the pressure on the adjusters to screw them in though which was a pain!
I've set the top adjuster lower than the bottom = more load on the bottom leaves. i did this because tims bay is lowered with only one adjuster in the top tube and rides great! so i thought id try it on the bug.
Anyone else done any experimenting with their adjuster settings?
