Go Back   VZi, Europe's largest VW forum, community and sales > Tech Forums > Aircooled Mechanical Tech
Aircooled Mechanical Tech A Q & A Forum devoted to Aircooled Mechanical Issues. Got a problem? Then ask in here. Please, no 'For Sale' or 'Want To Buy' ads, plugs for your 'business', links to 'for sale' ads or Ebay links to your (or your mate's) auction (use the VZi 'Classifieds' section) - this also includes thinly veiled 'What's My Car Worth?' threads and "Who Can Sell Me A . . ." posts.Forum sponsored by www.machinemart.co.uk
Machine Mart
Old 14-03-2008, 08:34 AM   #1
moscoworbust
moscoworbust's Avatar
Default Ever used HYCOTE spray paint? How many 400ml can to paint a car?
Hi,
has anyone ever used HYCOTE spray paint.It's cheap and i'm thinking of using it to paint the outside of the car till I can afford a proper paint job.
P.S. How many cans of 400ml to cover the outcide of a bug? 12 of paint and 12 of laquer?
My build: http://www.volkszone.co.uk/VZi/showthread.php?t=261383
-1972 beetle, chopped, sectioned, road legal drag car
-1993 mini rio, 1.8 vvc, close ratio,
-1972 MGB GT, perfect
-Peugeot 106
moscoworbust is offline   Reply With Quote
Old 14-03-2008, 08:45 AM   #2
David.H
Dub Daddy
David.H's Avatar
Look for the 'Paint your car cheap' threads on here using enamel paint and a roller. Its a lot less messy than using spray cans and probably even cheaper.
David.H is online now   Reply With Quote
Old 14-03-2008, 08:55 AM   #3
Whitworth
Whitworth's Avatar
Send a message via MSN to Whitworth
I'm currently using hycote satin black on mine, its going on well and is a nice finish. Not too sure about how long it will stay looking good, but hycote seems to be the most popular option for doing it.
I've used 11 cans so far on mine, and i've done all of it apart from the front valance, so 12 sounds about right. If i were you, id go for 14 or so, just to be on the safe side.
As for the laquer, i would imagine it goes on like the paint, in which case the same amount.
Its worth getting a spray gun trigger, gives you alot more control and means your fingers dont die. Something like this: http://www.halfords.com/webapp/wcs/s...tegoryId_90910
My '72 resto thread
Whitworth is offline   Reply With Quote
Old 14-03-2008, 09:37 AM   #4
moscoworbust
My frind did the enamel stuff, with the electric spray gun . It was incredibly messay and required a lot of sanding.
i've actualy got that stuff in black and an electric gun too, just a bit to scared too do it. So HYCOTE seems the best option, especially as I'm only going white. The roller technique just seems a little odd. And 100 quid for 12 cans of each (primer, white and laquer) can't be too bad. With little or no sanding, just a quick rub down to flatten back between coats.
Metal head Dandy, how many coats did you get? I'm hoping for 2 of the colour and 2 of laquer from the 12 cans of each.
-Peugeot 106
Old 14-03-2008, 09:47 AM   #5
Tomarse
Tomarse's Avatar
Location: Live in Biddestone near Castle Combe and work in Bristol
I did my whole car in Hycote satin black in 13 cans (no lacquer).
I've since done it with the roller method but it was a million times MORE hassle.
Tomarse is offline   Reply With Quote
Old 14-03-2008, 10:02 AM   #6
moscoworbust
Where is the cheapest place too buy primer, gloss black, gloss white and laquer all of the same brand?
I'm definitely spraying, lots of laquer if the key, i reckon
-Peugeot 106
Old 14-03-2008, 10:03 AM   #7
moscoworbust
in an aerosol
-Peugeot 106
Old 14-03-2008, 11:15 AM   #8
magicfiver
PLEASE UPDATE YOUR EMAIL!
magicfiver's Avatar
Send a message via AIM to magicfiver Send a message via MSN to magicfiver
i did my car in hycote flat black. 11 cans (but didnt paint the decklid) has lasted the winter pretty well and hasnt needed that much touching up
id avoid the hycote coloured stuff if i were you. i used to use it to touch up my orange paint (before i went flat black) and every single can is a different shade (hence why i went flat black)
My Resto threads - Pt 1, Pt 2
Deutschworks - Volkswagens in Norwich
magicfiver is offline   Reply With Quote
Old 14-03-2008, 12:15 PM   #9
purplepete
I've never thought of spraying a whole car with cans!
But couldnt you just buy a litre of cellulose and a refillable aerosol?
purplepete is offline   Reply With Quote
Old 14-03-2008, 02:09 PM   #10
moscoworbust
How do you refill it? Hwere do you get gas, etc?
-Peugeot 106
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SupportingSupporting Brad's Cancer Foundation One of the largest message boards on the web !
