Originally Posted by Scott-16v!
Nice work so far, good to see another 1303 being saved!
cheers man...
shame that they get scrapped so readily... mine would have if i hadn't bought it!
tidied the wiring up today and it now has a hooter and matching bulbs in the front
here we go:
had a play with the grinder, got abit muckier than i first thought and ended up playing about with the new sill after removing the front inner wing due to rot!
: nasty business, there was alott of pop rivets used here with tins and shite
so off it all came
and then more cutting and faffing about, with the welder etc
all was going well...
Now with both the sills fitted and the floorpan outers seamed in i started looking for other little bits to weld up. With it beng high up on some landrover axel stands i had a bash at the framehead bottomplate which needed some major fabrication work, with that and the bulkhead welded up i moved onto silly things like door pillars.
The framehead has maybe 2 years life in it( this is ok because i'm having the body off then to do new front and rear bulkheads, full floorpans ( the thicker heritage ones) framehead, and some other goodies
I origanally thought it'd be MOT'd by now but due to people welding with seamsealer and underseal and bits of tin i've been mending bodges!
( more time went by)
I've now fitted all the following panels(or payed out for them)
2 sills, 2 pan outers, rear quarterpanel, front and rear bumpermounts, pasanger side full arch, 3 new wings, about 4 sheets of tin, front and rear aprons. some bumpers and a door, a whaletail etc ( cheers to Dale for these and all his support with the project
It is now on it's feet with all working lights and brakes, the repairs are all primed and the wings are blown in blue untill i can get the yellow paint for it.
I will update this more at some point if it gets views
All the things that i've fitted are to an "ok" standard i think but we'l see... There's no more coke can+ seamsealer repairs!
The joys of being aircooled and tax free
What does everyone think? I probably missed some stuff out so sorry in advancee
