How cold does it need to get before the water in an engine block freezes...... - VW Forum - VZi, Europe's largest VW, community and sales
Old 29-10-2008, 01:49 AM   #1
Mr Big
I really must get out more
Mr Big's Avatar
Default How cold does it need to get before the water in an engine block freezes......
I've just realised the VR6 I bought earlier in the year as a project is sat outside in this lovely weather and I have no idea if it has any antifreeze in it The front end is right up against the house so it might keep a bit of warmth into it.
If there was no antifreeze in it, how cold you reckon it will have to get for the water inside the block to freeze. Cracked waterways is not something I fancy.
Should I just go outside and dump the water out of it onto the drive?
Wanted:
Tombstone beetle rear wings - Genuine or good quality repro. Slight oversize also considered.
Please PM if you can help.
Mr Big is offline   Reply With Quote
Old 29-10-2008, 01:51 AM   #2
Gal
Gal's Avatar
er 0C as thats when water freezes?
DO NOT ASK ME FOR HELP:lol::lol:
Gal is offline   Reply With Quote
Old 29-10-2008, 01:52 AM   #3
TomD
TomD's Avatar
I'd say the water needs to be about 0 degrees C!.
TomD is offline   Reply With Quote
Old 29-10-2008, 01:54 AM   #4
Mr Big
Mr Big's Avatar
Yeah thanks for that useful info
Its not like its water sat on the ground though. Its inside the engine block which is inside the car, so its going to be insulated from ambient temp.
Wanted:
Old 29-10-2008, 02:03 AM   #5
BenEssex
BenEssex's Avatar
Just take the lid off the reservoir , that way if it does freeze it will just expand out the reservoir and no damage will be done.
http://www.myspace.com/romford
BenEssex is offline   Reply With Quote
Old 29-10-2008, 02:04 AM   #6
andy_k
andy_k's Avatar
Trading feedback: (6)
anything down to -4 or -5 and you should be OK. After that, well you are on your own. Just 1 or two litres of cheap anti freeze would protect you from freezing in this country
http://www.ak3dgfx.com
andy_k is offline   Reply With Quote
Old 29-10-2008, 02:07 AM   #7
Samage
Samage's Avatar
With my limited mechanical knowledge, I'd say this... find an all-night garage and buy some antifreeze.
You get born, you keep your head down, then you die. If you're lucky.
Samage is offline   Reply With Quote
Old 29-10-2008, 02:10 AM   #8
bfg69bug
bfg69bug's Avatar
VZi Member Sponsor
Trading feedback: (4)
throw an old blanket under the bonnet too
my old man sent me a letter from prison once, it said, if you dont wanna end up like me, stay away from crime, women and drugs. thing is, it dont leave ya with much else to do does it?
bfg69bug is offline   Reply With Quote
Old 29-10-2008, 02:13 AM   #9
john.stone
john.stone's Avatar
Trading feedback: (3)
How so? If the air temp. is 0 degrees then the block will be as cold as anything else in the vicinity. You'll blow the core plugs first even if you do remove the rad/reservoir cap.
john.stone is offline   Reply With Quote
Old 29-10-2008, 02:17 AM   #10
Mr Big
Mr Big's Avatar
Fook me its cold out there! Just been out to pull the expansion tank cap off, push it right up to the house and drop an old blanket under the hood.
Hopefully it will be ok until tomorrow afternoon when I can pick up an antifreeze tester. Cooling system is full at the moment so cant top it up with antifreeze. And its pitch black outside so I cant find the bottom hose to drain some out.
Its not in use at the moment anyway and its supposed to be going in for a coolant flush and refill next monday. Just wish i'd remembered when it was a bit lighter outside.
Wanted:
