Electrics New Beetle - Boot wont open - VW Forum - VZi, Europe's largest VW, community and sales
Old 06-02-2009, 11:52 PM   #1
Spot441
Spot441's Avatar
Trading feedback: (5)
Default New Beetle - Boot wont open
I suspect it electrical. Boot wont open from either the key fob or the button inside the car.
Have tried with the key lock turned either way!
1) Is it likely to be fuse or actuator?
2) How do I get the boot open to look?
Neil
Spot441 is offline   Reply With Quote
Old 06-02-2009, 11:55 PM   #2
Shamrockez
Shamrockez's Avatar
what year is it? Does it have the swivel badge? And can you hear any noises?
www.evvo.co.uk New Beetle Owners Club. Find us on Facebook!
Shamrockez is offline   Reply With Quote
Old 07-02-2009, 12:08 AM   #3
Spot441
Spot441's Avatar
Its 2004. 54 reg. No noises. Indicatoes just flash...nowt happens!
Old 07-02-2009, 12:08 AM   #4
Spot441
Spot441's Avatar
thet should be Indicators!!!:-)
Old 07-02-2009, 12:12 AM   #5
Shamrockez
Shamrockez's Avatar
probably either a fuse gone or the motor. Check the fuses first. I belive the motor is under the plastic panel on the boot lid - I dunno if you can get that off easily with the boot closed though?
Another thing to try would be to remove the fuel flap/boot open switch from the door card and swap the connections around, just to rule that one out, but if it doesn't work on the key, then that's unlikely.
Old 07-02-2009, 12:19 AM   #6
Shamrockez
Shamrockez's Avatar
quick search....
http://www.evvo.co.uk/forums/showthr...highlight=boot
http://newbeetle.org/forums/showthre...ght=trunk+shut
http://www.newbeetle.org.uk/justbugg...highlight=boot
Old 07-02-2009, 12:24 AM   #7
Black Sheep
Black Sheep's Avatar
Go into the boot from the inside and look for the emergency boot release on the tailgate near the lock, it has the boot open symbol on it.
Pull the bung out and carefully pull the cord, this is directly on the release mechanism so the tailgate will open, then you can remove the plastic trim and check the motor.
A Baja in progress
http://www.freewebs.com/ukbajaregist...jabrothers.htm
(the red one)
Black Sheep is offline   Reply With Quote
Old 07-02-2009, 12:43 AM   #8
smoggyrich
smoggyrich's Avatar
I've heard that you can have this problem if your battery isn't fully charged.
Sounds stupid i know, but have you tried the button inside the car when your engine is running/ticking over?
smoggyrich is offline   Reply With Quote
Old 07-02-2009, 06:38 PM   #9
Spot441
Spot441's Avatar
Thanks, guys for all your help. I managed to open it with the pull cord this afternoon.
It works intermitantly now!
I think that its a combination of the cold, being left out all yesterday. I'll see how it goes for a bit!
Old 05-05-2009, 05:23 PM   #10
tfox456
Chat Virgin
I have the same problem and am trying to manually open (as above). I have not been able to locate the manual opening cord. Can anyone help me by telling me exactly where it is?
tfox456 is offline   Reply With Quote
