Electrics t25 radio wiring???? - VW Forum - VZi, Europe's largest VW, community and sales
Old 28-03-2009, 10:48 PM   #1
veggie
Chat Virgin
Default t25 radio wiring????
Trying to wire a jvc cd player into my t25. The van has brown, a lightblue and a red wires. Which do what?
cheers
veggie is offline   Reply With Quote
Old 29-03-2009, 12:17 AM   #2
veggie
Chat Virgin
is the blue/white one ignition live? and is this what i should wire the one one the head unit marked acsessory too???
Old 29-03-2009, 12:34 AM   #3
mixster
Trading feedback: (3)
Have you got an electrical tester? Ignition off, test the wires. The one that lights up is your permanent live. Then turn the ignition on, and see which one lights up in addition to the first one. That's your ignition live. Then put the clip from your tester onto the first live wire, and test the remaining wires (NOT the other live one though!). The one that lights up now is your earth. The rest will probably be speakers.
mixster is offline   Reply With Quote
Old 29-03-2009, 12:37 AM   #4
Speedy Jim
Speedy Jim's Avatar
Brw is earth.
Red is live (+) all the time. It should be fused.
Blk is switched with Ignition. Should be fused.
Blk/Yell is also switched for accessories. You can pick that up from Fuse #10.
http://www.vintagebus.com/wiring/index.html
look for the Vanagon diagrams
HTH
SJ
Speedy Jim is offline   Reply With Quote
Old 29-03-2009, 12:38 AM   #5
Speedy Jim
Speedy Jim's Avatar
Good advice from Mixster; double check with a tester.
Old 29-03-2009, 07:04 AM   #6
phade
I really must get out more
phade's Avatar
Personally, I would buy some different coloured reels of wire, some crimps, a crimp tool, run those wires from the radio to the unfused side of the fuse box (ground wire to the chassis) and do the job properly.
It's very easy to get access to the type 2 T3's fuse box. Just undo 3 bolts and carefully flip it downwards.
From the radio end:-
Brown to chassis
Red to unfused side of fuse 7 (radio) or any B+ (battery live) terminal from the fuse box
Yellow to unfused side of fuse 10 or any switched live terminal from the fuse box
My VW rides:- 1973 1300 Beetle, 1982 2.0 aircooled Ci Autohomes Komet Type 2 T3 Camper
My non VW rides: 1985 Reliant Rialto 2 Estate, 1988 Reliant Rialto SE Hatch, 2007 Citroën C1
phade is offline   Reply With Quote
Old 30-03-2009, 01:47 PM   #7
Kafer_meister
Kafer_meister's Avatar
Bear in mind that if you connect the switched live to a switched live source, you will only be able to use the radio when the engine is running or your ignition is live (which will burn out your coil). T25's (and most earlier VW's) don't have a 3 position ignition switch. I'm just going to wire the switched and permanent lives from the stereo to a permanent (fused) live from the fuse box (well leisure battery in my case).
“Bicycles are almost as good as guitars for meeting girls.”
Bob Weir, Grateful Dead
Kafer_meister is offline   Reply With Quote
