Click here for Just Kampers
Go Back   VZi, the UK's largest VW forum, community and sales > Volkszone Classifieds > Items For Sale - AUTO
Items For Sale - AUTO Private sales only please. Commercial and 'regular' sellers, please take a banner advert or become a Member Sponsor and support the site before running your 'business' through VZi. Please read the sticky threads BEFORE posting - it may save you time in the long run. Forum sponsored by www.fishbrain.biz/
Fishbrain Awnings
Old 25-06-2009, 09:44 AM   #1
the jester
Default performance engine parts -2276
i have a 2276 in bits
was going to build it and sell it but dont have the time
it is available as a lot if you want
the engine came from the states, ran for 5 minutes at idle then spun a rod bearing
ive had the crank & rod checked and all that was required was a polish.
all bits bar being abit oily are pretty much as new, as stated they ran for 5 minutes, if anything is not as described ill refund.
case
clearenced for stroker crank & cut for 94s full flow oil. £350
heads £450
42 X37 stainless valves, dual springs, steve tims stage 2 head port job, cromo retainers
scat c45 cam £20
straight cut gears £50
engle FK8 BRAND NEW, I HAVENT EVEN PINCHED THE STICKER! £50
forged crank, 82mm cheavy journal £200
it has been balanced with....
forged flywheel £75
( i realise i have taken a pic of the crank with the journals covered in assembly lube, this is not to hide damage, i was assembling the engine and found a bit missing which halted assembly i will get pics of the shiney journals as required)
h beam rods, again chevy , ill need to check lenght, either 5.5 or 5.4
£150
scat 1.4/1 ratio rockers £200
webber/dellorto intake manifolds,£60
forged 94mm stroker B&P AA i think, ill double check
the jester is offline   Reply With Quote
Old 25-06-2009, 09:51 AM   #2
the jester
fuel pump, borrowed by a buddy to drive home so used for more than 5 mins £20
empi 4into1 exzaust system, its new but sruffy £100
autometer 3and abit inch tach, shifter light , programable, includes stainless mount, £100, this is new never wired up
custom exhaust part£50
this replaces the rear pipes and silencer and allows the fitting of a type one quiet pack to type4 engine, this was for a 75 bay 2.0L set up, attaches to the heat exchangers
empi breather box£15
flywheel gland nut £15
carb balancer
£20
as always pm is the best way to get me#
dont be shy to make an offer
the more you want the more discount i tend to give
cheers
Old 25-06-2009, 10:08 AM   #3
the jester
ALSO HAVE THIS!
2165 180bhp
ive instaled it and done about 200 miles in it
£2k for the block
£3500turnkey, NOS dellorto45s, speedshop stainless zaust,csp linkage & breather,match ported manifolds, goes like shit off a shinney shovel
http://www.volkszone.co.uk/VZi/showthread.php?t=498387
Old 25-06-2009, 01:12 PM   #4
von-van
von-van's Avatar
Would you take 100 for fuel pump And exhaust ?
wanted OG twinport cylinder tin
von-van is offline   Reply With Quote
Old 25-06-2009, 02:54 PM   #5
the jester
sure i would
Old 25-06-2009, 02:58 PM   #6
the jester
94mm B&Ps £150, missed that one
Old 25-06-2009, 03:05 PM   #7
the jester
ive been asked if the case is ali or mag, i honestly cant remeber, ill check at the weekend
Old 25-06-2009, 03:09 PM   #8
typeoneman
doesn't even like vw's
typeoneman's Avatar
please can i buy the tacho mount seperatly and if so how much?
thanks
typeoneman is online now   Reply With Quote
Old 25-06-2009, 03:16 PM   #9
the jester
£20
Old 25-06-2009, 03:18 PM   #10
typeoneman
typeoneman's Avatar
i think they are less than that new aren't they? i'll give you £15 inc P&P?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SupportingSupporting Brad's Cancer Foundation One of the largest message boards on the web !
