How long do points stay on your licence? - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Old 09-02-2010, 03:01 PM   #11
chrisvrscrx
chrisvrscrx's Avatar
The following is a guide to the number of penalty points a court may impose, it does not reflect the fact that some offences may incur a disqualification. The offence code and penalty points will be shown on your driving licence and must stay there for four or eleven years depending on the offence.
Check the codes on your driving licence against the list below.
Accident offences
Offence codes AC10 to AC30 must stay on a driving licence for four years from date of offence.
Code Offence Penalty points
AC10 Failing to stop after an accident 5-10
AC20 Failing to give particulars or to report an accident within 24 hours 5-10
AC30 Undefined accident offences 4-9
Disqualified driver
Offence codes BA10 and BA30 must stay on a driving licence for four years from date of offence.
BA10 Driving while disqualified by order of court 6
BA30 Attempting to drive while disqualified by order of court 6
Careless driving
Offence codes CD10 to CD30 must stay on a driving licence for four years from date of offence.
CD10 Driving without due care and attention 3-9
CD20 Driving without reasonable consideration for other road users 3-9
CD30 Driving without due care and attention or without reasonable consideration for other road users 3-9
Offence codes CD40 to CD70 must stay on a driving licence for eleven years from date of conviction.
CD40 Causing death through careless driving when unfit through drink 3-11
CD50 Causing death by careless driving when unfit through drugs 3-11
CD60 Causing death by careless driving with alcohol level above the limit 3-11
CD70 Causing death by careless driving then failing to supply a specimen for 3-11
Offence codes CD80 and CD90 must stay on a driving licence for four years from date of conviction.
CD80 Causing death by careless, or inconsiderate, driving 3-11
CD90 Causing death by driving: unlicensed, disqualified or uninsured drivers 3-11
Construction and use offences
Offence codes CU10 to CU80 must stay on a driving licence for four years from date of offence.
CU10 Using a vehicle with defective brakes 3
CU20 Causing or likely to cause danger by reason of use of unsuitable vehicle or using a vehicle with parts or accessories (excluding brakes, steering or tyres) in a dangerous condition 3
CU30 Using a vehicle with defective tyre(s) 3
CU40 Using a vehicle with defective steering 3
CU50 Causing or likely to cause danger by reason of load or passengers 3
CU80 Using a mobile phone while driving a motor vehicle 3
Reckless/dangerous driving
Offence codes DD40 to DD80 must stay on a driving licence for four years from date of conviction.
DD40 Dangerous driving 3-11
DD60 Manslaughter or culpable homicide while driving a vehicle 3-11
DD80 Causing death by dangerous driving 3-11
DD90 Furious driving 3-9
Drink or drugs
Offence codes DR10 to DR30 must stay on a driving licence for eleven years from date of conviction.
DR10 Driving or attempting to drive with alcohol level above limit 3-11
DR20 Driving or attempting to drive while unfit through drink 3-11
DR30 Driving or attempting to drive then failing to supply a specimen for analysis 3-11
Offence codes DR40 to DR70 must stay on a driving licence for four years from date of offence.
DR40 In charge of a vehicle while alcohol level above limit 10
DR50 In charge of a vehicle while unfit through drink 10
DR60 Failure to provide a specimen for analysis in circumstances other than driving or attempting to drive 10
DR70 Failing to provide specimen for breath test 4
Offence code DR80 must stay on a driving licence for eleven years from date of conviction.
DR80 Driving or attempting to drive when unfit through drugs 3-11
Offence code DR90 must stay on a driving licence for four years from date of offence.
DR90 In charge of a vehicle when unfit through drugs 10
Insurance offences
Offence code IN10 must stay on a driving licence for four years from date of offence.
IN10 Using a vehicle uninsured against third party risks. 6-8
Licence offences
Offence codes LC20 to LC50 must stay on a driving licence for four years from date of offence.
LC20 Driving otherwise than in accordance with a licence 3-6
LC30 Driving after making a false declaration about fitness when applying for a licence 3-6
LC40 Driving a vehicle having failed to notify a disability 3-6
LC50 Driving after a licence has been revoked or refused on medical grounds 3-6
Miscellaneous offences
Offence codes MS10 to MS90 must stay on a driving licence for four years from date of offence.
MS10 Leaving a vehicle in a dangerous position 3
MS20 Unlawful pillion riding 3
MS30 Play street offences 2
MS50 Motor racing on the highway 3-11
MS60 Offences not covered by other codes
As Appropriate
MS70 Driving with uncorrected defective eyesight
3
MS80 Refusing to submit to an eyesight test 3
MS90 Failure to give information as to identity of driver etc 6
Motorway offences
Offence code MW10 must stay on a driving licence for four years from date of offence.
MW10 Contravention of special roads regulations (excluding speed limits) 3
Pedestrian crossings
Offence codes PC10 to PC30 must stay on a driving licence for four years from date of offence.
PC10 Undefined contravention of pedestrian crossing regulations 3
PC20 Contravention of pedestrian crossing regulations with moving vehicle 3
PC30 Contravention of pedestrian crossing regulations with stationary vehicle 3
Speed limits
Offence codes SP10 to SP50 must stay on a driving licence for four years from date of offence.
SP10 Exceeding goods vehicle speed limits 3-6
SP20 Exceeding speed limit for type of vehicle (excluding goods or passenger vehicles) 3-6
SP30 Exceeding statutory speed limit on a public road 3-6
SP40 Exceeding passenger vehicle speed limit 3-6
SP50 Exceeding speed limit on a motorway 3-6
Traffic direction and signs
Offence codes TS10 to TS70 must stay on a driving licence for four years from date of offence.
TS10 Failing to comply with traffic light signals 3
TS20 Failing to comply with double white lines 3
TS30 Failing to comply with "'Stop'" sign 3
TS40 Failing to comply with direction of a constable/warden 3
TS50 Failing to comply with traffic sign (excluding 'stop' signs, traffic lights or double white lines) 3
TS60 Failing to comply with a school crossing patrol sign 3
TS70 Undefined failure to comply with a traffic direction sign 3
Special code
Offence code TT99 must stay on a driving licence for four years from date of conviction.
Code Offence
TT99 To signify a disqualification under 'totting-up' procedure. If the total of penalty points reaches 12 or more within three years, the driver is liable to be disqualified
Theft or unauthorised taking
Offence codes UT50 must stay on a driving licence for four years from date of offence.
UT50 Aggravated taking of a vehicle 3-11
Aiding, abetting, counselling or procuring
Offences as coded, but with 0 changed to 2 eg LC10 becomes LC12.
Causing or permitting
Offences as coded, but with 0 changed to 4 eg LC10 becomes LC14.
Inciting
Offences as coded, but with the end 0 changed to 6 eg DD40 becomes DD46.
Non-endorsable offences
Some offences are non-endorsable. A non-endorsable offence is an offence which courts do not endorse onto your paper counterpart. No penalty points are attributed to these offences but they carry a period of disqualification.
At the end of the disqualification (over 56 days) you will have to apply for a renewal licence together with the appropriate fee. Any queries about offences and endorsements should be directed to the convicting court.
Hi Five
chrisvrscrx is offline   Reply With Quote
Old 09-02-2010, 03:49 PM   #12
Prawn_Star
Accident offences
Disqualified driver
Careless driving
Drink or drugs
Insurance offences
Licence offences
As Appropriate
3
Motorway offences
Speed limits
Special code
Code Offence
Inciting
I have nothing to add to the thread but I know quoting this looooooooooooooong post will piss some people off.
Prawn_Star is offline   Reply With Quote
Old 09-02-2010, 03:50 PM   #13
Carbon
Carbon's Avatar
Trading feedback: (6)
Carbon is offline   Reply With Quote
Old 09-02-2010, 04:03 PM   #14
chrisvrscrx
Ah well
Hi Five
Old 09-02-2010, 04:24 PM   #15
dogfood
dogfood is offline   Reply With Quote
Old 09-02-2010, 05:17 PM   #16
donnyburger
donnyburger's Avatar
Well that's that cleared up!
[SIGPIC][/SIGPIC]
^^^It's a clicky linky thing!^^^
I've never liked seafood.
donnyburger is offline   Reply With Quote
