Engine flat spot cure please - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-03-2010, 06:38 PM   #1
wodan
Default flat spot cure please
hi..really need some help with this one..
71 bay 1600 TP..ticks over lovely but when you go to pull away BIG flat spot...now i have had every thing set up spot on..you name it it has been adjusted..professionally ...we found out that removing the oil bath the flat spot went away..so changed oil in bath .re fitted oil bath...FLAT spot..again.... leave it off almost ok...so i bought a chrome pancake .pull away.Flat spot..bugger ! ..now the car will not tick over even without the various air filters( i had been running it without any filter for comparison sake)
where do i go now...??
wodan is offline   Reply With Quote
Old 07-03-2010, 06:41 PM   #2
jacks
jacks's Avatar
Location: Northwich, Cheshire, 07739342965 if you need help
what carbs dizzy etc have you got on it
Dave :D:D:D
dont worry if you dont understand what i type, i dont understand it either :D:D:D
what ever you do DONT take your belly pans off unless you want a head ache :rolleyes:
jacks is offline   Reply With Quote
Old 07-03-2010, 06:49 PM   #3
David.H
David.H's Avatar
I'm guessing 009
David.H is offline   Reply With Quote
Old 07-03-2010, 07:16 PM   #4
jacks
jacks's Avatar
Originally Posted by d4vidh74 View Post
I'm guessing 009
my first thought would be that or if not an air leak on rubbers between carb mainfolds and engine manifolds or carb needs a rebuild
Dave :D:D:D
Old 07-03-2010, 07:17 PM   #5
wodan
correct solex 34 and a 009 dizzy...but why when removing the oil bath did it run a lot better...?
Old 07-03-2010, 09:37 PM   #6
phade
I really must get out more
phade's Avatar
The 009 dizzy should be tossed in the bin and be replaced with a Bosch SVDA dizzy, the correct metal vacuum pipe and the vacuum hoses connected in the correct order.
Moby5153 and other people on here will know how those hoses should be connected on a 1600 single/twin port early bay.
My VW rides:- 1973 1300 Beetle, 1982 2.0 aircooled Ci Autohomes Komet Type 2 T3 Camper
My non VW rides: 1985 Reliant Rialto 2 Estate, 1988 Reliant Rialto SE Hatch, 2007 CitroŽn C1
phade is offline   Reply With Quote
Old 07-03-2010, 10:16 PM   #7
Mucky Green
Wodan. Where are you?
Here endeth the lesson... None of this is hearsay, or something I heard in a pub.
Just plain and simple first hand experience.
Mucky Green is offline   Reply With Quote
Old 08-03-2010, 12:18 AM   #8
wodan
hi
i`m in essex nr dartford tunnel
Old 08-03-2010, 10:17 AM   #9
Mucky Green
I always worry about a professional tune up that doesn't cure anything.
Don't go buying or throwing anything away.
First take a look down the carb and see if the spray jet is spraying.
Then take the idle jet out from under the choke unit and see if it is blocked.
If you can, get a can of spray choke and carb cleaner and blast out the idle circuit.
Believe it or not, an 009 stands as much chance of being your problem as the recent earthquake in Peru. So... If you didn't feel the earth move.... Change your engine tuner before you change your 009. Someone has missed something very basic.
Old 08-03-2010, 10:23 AM   #10
twotonekate
twotonekate's Avatar
I'm guessing 009
Seconded
'Operator? Give me the number for 911!' - HJS
twotonekate is offline   Reply With Quote
