Engine MK1 gti temp gauge on dash not working? - VW Forum - VZi, Europe's largest VW, community and sales
Old 20-09-2010, 09:58 AM   #1
barnwall
Chat Virgin
barnwall's Avatar
Default MK1 gti temp gauge on dash not working?
Hi,
A while back my coolant temp gauge on the dash of my golf mk1 started acting a little funny.
Firstly the red light would flash for a couple of minutes and then go back off.
About a week later then the needle seemed to indicate the coolant was not at a high enough temperature.
And then the needle failed to give any reading at all.
I have checked the whole cooling system during this and everything was working properly.
Coolant levels were good, circulation was fine, water pump good, fan worded correclty. Everything seemed fine and the car was not overheating.
This led me to believe that is was a sender fault.
But before I sourced this I put in a new thermostat. (didn't help)
Just this weekend I put in a new sender after days of tracking down the part.
I was sure this was the problem. But there is still no reading.
Just to be safe I have since put in a new rad and rad fan & motor.
So what could it be??
Perhaps the gauge in the dash needs to be replaced?
And thoughts on this much appreciated.
Thanks,
Richard
barnwall is offline   Reply With Quote
Old 21-09-2010, 01:54 PM   #2
k_wyndham_t
k_wyndham_t's Avatar
I had same fault on MK2 polo I changed the instrament binecle for another reason and it went away, assume gauge or more likely that horible plastic circuit board was at fault.
k_wyndham_t is offline   Reply With Quote
Old 22-09-2010, 07:44 PM   #3
bug.mania
bug.mania's Avatar
Trading feedback: (4)
failing that change the temp senders on the engine they should be on the block on a plastic or metal flange, im unsure what colour does what ring vw and they can get them for about 13 iirc
'75 late bay - nearly finished ready to be sold :(
'72 Baja - needs finishing
'14 UP! - sold
'14 new beetle - sold :(
'09 golf - sold and regretting it :(
bug.mania is offline   Reply With Quote
Old 27-09-2010, 12:34 PM   #4
barnwall
Chat Virgin
barnwall's Avatar
Thumbs up Replacement gauge?
Thanks,
I think removing the binecle is next on the list.
I have already changed the temp sender in the engine (unfortunately it was more like 100 euro rather than 13 pounds :/)
I was sure this would fix the problem but alas I will have to get my hands on the fiddly bits on the dash...sigh...
Any suggestions for finding a replacement gauge?
Old 27-09-2010, 07:25 PM   #5
BORISTHEBLADE
BORISTHEBLADE's Avatar
earth the wire for the coolant temp gauge that goes to the sender, if the gauge moves all the way to the top then it is not faulty, if it does not it could be a wiring issue, check for continuity from dash loom to sender unit before stripping the dashboard.
Drive it like you stole it
BORISTHEBLADE is offline   Reply With Quote
Tags
coolant, golf, gti, mk1, tempertaure
