2 STROKE Any ONE good With Bike's CPI SM 50CC wont start??????? - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-07-2011, 01:11 AM   #1
karvoom
karvoom's Avatar
Default 2 STROKE Any ONE good With Bike's CPI SM 50CC wont start???????
Hi
I know this is not the best place to ask but fort i give it a try,
I have a CPI SM 50 59 plate which has the AM6 engine in it
couple of weeks ago as i was driving back from school, the bike started to feel like it was miss firing and stuttered to a holt,
i then kick started it and drove off 2 min latter it just turned off,
i kept on trying to start it and it wont so i left it for a min and then it would start for 5 mins and i ride it but it would randomly cut out again,
im not too good with electrics but i checked the fuel line and fuel in the fuel filter and there was fuel, i changed the spark plug, iv checked if there's volts going into the coil, which there was i checked if volts where coming out of the coil (12v) which there was,-i dont realy know how to use a volt meter but i managed to get it say 12v-lol
but there is no spark from the spark plug, when i kick start it the front headlight lights up so the stator must be working and it does randomly start sometimes, i just bought a brand new coil which has made no difference and i don't no what the problem is, i cart seem to get spark, but it does randomly spark which then starts the bike
so im guessing there's something electrical wrong, as i think the problem is no spark
could any of you guys help me???
karvoom is offline   Reply With Quote
Old 07-07-2011, 08:20 AM   #2
judgie
judgie's Avatar
Trading feedback: (4)
if the stator is working then it sounds like a bad conector somewere, recntly riden in the wet?
get you favorite water repelant spray out [dw40. duck oil etc] take each wireing conector of one at a time and clean them, pit back together and give them asuirt of the spray. also check for a brokien wire while your doing the conectors.
if that dont work then its time to start looking at at pick ups and cdi unit but that mostly means changing them for known good ones.
bike electrics can be a nightmere so good luck.
Power is nothing with out control, to control your power www.rnjmotorsport.co.uk
Northampton based speed shop
01327 830400
rob@rnjmotorsport.co.uk
judgie is offline   Reply With Quote
Old 07-07-2011, 09:07 AM   #3
Pyro
Pyro's Avatar
Check the vacuum pipe is not soft and collapsing when warm.
Failed London Mayoral candidate 2008, failed comedian. (Personal appearances now have to include clothes because of bail conditions)
Sometimes it seems, the universe is a bitch, but she is not really, you are an insignificant tiny little piece of nothing. The universe does not care about you, you want the universe to notice you? Then get off your arse and do something worthwhile!
Pyro is offline   Reply With Quote
Old 07-07-2011, 11:49 PM   #4
karvoom
karvoom's Avatar
Thanks for that, Ya i did what you said and managed to see a tiny bit of carosion on some of the connececter but it didnt look bad, and still no spark, or very very week spark,
I put a negative voltmeter wire on the HT lead and connect the other end to the battery to see what reading i got which was normally 12v but as iv left the battery to drop its gone to 7v, but when i kick start it the voltage from the HT lead stays the same, but the front lights light up when i kick start,
Old 08-07-2011, 12:02 AM   #5
nathan93
nathan93's Avatar
lmao mine was doing exactly this last week, check every connection from the stator cdi, ignition etc also check your reeds
mine turned out to be old cdi wires id forgotten to tape up touching eachother
try scootershack.co.uk or scooternations.com have a look round should find some great help on there or ask in the workshop
nathan93 is offline   Reply With Quote
Old 08-07-2011, 12:05 AM   #6
nathan93
nathan93's Avatar
can you get another cdi/coil to try it might be that the coils braking down, also try testing it with the voltmeter
Old 08-07-2011, 12:18 AM   #7
karvoom
karvoom's Avatar
Yep bought a new coil still no spark, or the rare tiny spark, I have a shitty volt meter just not too sure how to use it, I turnerned it left where it says something like 20 v and that show 12v from the battery and every where else on the bike, I had a look at Cdi and there looked like nothing wrong, but the volts never increases when kick started so I think it might be something with that, but from the coil it reads 12v even when I don't turn the ignition, would that help?
Old 08-07-2011, 12:27 AM   #8
G11NNR
G11NNR's Avatar
not too sure about your bike but a lot have 3 windings in the magneto 1 for ignition 1 for headlights and 1 for charging, maybe the winding in the magneto for ignition is breaking down and causing the low/intermittent spark
Gunners
my 72 crossover bay resto
http://www.volkszone.com/VZi/showthread.php?t=804996
G11NNR is offline   Reply With Quote
Old 08-07-2011, 01:07 AM   #9
Mr.Orange
Mr.Orange's Avatar
Switch the fuel tap to reserve....
Mr.Orange is offline   Reply With Quote
Old 08-07-2011, 06:15 AM   #10
Pyro
Pyro's Avatar
Really stupid question, but have you changed the plug?
Tags
50cc wont start
