Gearbox Mk4 golf 1.6 SE automatic[gearbox prob] - VW Forum - VZi, Europe's largest VW, community and sales
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 18-07-2011, 03:19 PM   #1
tangalooma flyer
Default Mk4 golf 1.6 SE automatic[gearbox prob]
I have the above car which has started to play up a bit, it drops down a gear when accelerating then picks up again. Sometimes will rev too far before engaging.I can drive it but its very annoying, will clonk into gear occasionally as well. I thought might need some fresh oil in box and filter, are these boxes prone to loosing oil? as it feels as if theres a lack of oil, is it an easy fix, cheers Andy.
tangalooma flyer is offline   Reply With Quote
Old 18-07-2011, 05:15 PM   #2
fr05ty
I really must get out more
fr05ty's Avatar
may not lose oil but will need changing now and again. give it a service before you start panicking
i am a unique
http://www.youtube.com/watch?v=ZYmbR63HESE
fr05ty is offline   Reply With Quote
Old 19-07-2011, 11:26 AM   #3
Crasher
Crasher's Avatar
It may need an oil change and the pan filter replacing but doing an oil change on these 01M boxes requires that you are able to see the ATF temperature is between 35 and 45 degrees using a diagnostic computer. You will need to replace the filer cap cover, part number 01M 321 435 B, the pan gasket is 096 321 370 and the filter is 01M 325 429. The recommended VAG oil is 5.3 litres of G 052 162 A2 which is a special yellow ATF that is available from a few companies such as Febi. At the same time as using the diagnostic computer for the level check, the fault codes stored on the engine and gearbox computers should be checked to see if anything relevant is stored. Certain engine management faults can cause gearbox issues,
Crasher is offline   Reply With Quote
Old 19-07-2011, 03:20 PM   #4
tangalooma flyer
Thumbs up
Cheers people, theres a gearbox specialist on the Island I'll give him a visit,if he says what you just said I'll know he knows what hes doing. Thanks again.
Andy
Old 21-08-2011, 08:36 AM   #5
Alpinestarhero
Chat Virgin
Sorry to ressurect an older thread, and I am also a newbie here. My fiance has what seems to be a similar problem with her 1.6 auto, whereby the shifting from 2nd to 3rd does not occur smoothly and properly; there seems to be a delay between shifts, causing the engine to increase in revs while there is no load on it. We have had the gearbox oil changed, and the ECU threw up no fault codes. We have had the gearbox out and inspected with a full refresh (so, replacment of parts then) but still the problem persists.
Can anyone shed any further light on this problem? I am wondering if it is a throttle position sensor problem or something similar
Thanks,
Matt
Alpinestarhero is offline   Reply With Quote
Old 21-08-2011, 02:24 PM   #6
Crasher
Crasher's Avatar
Which year and engine code?
Old 16-11-2012, 09:34 PM   #7
rlau1010
Chat Virgin
Please can anyone help, the error code was generated after my car service:
00777 - Accelerator position sensor (G79) 27-10 - Implausible
00529 - Engine speed signal missing 35-00 - -
01314 - Engine control module 49-10 no communication - intermittent
It is something seriouos? and is it expensive to fixed?
rlau1010 is offline   Reply With Quote
Old 16-11-2012, 11:28 PM   #8
Crasher
Crasher's Avatar
It would be nice to know what the car is!
Old 17-11-2012, 09:54 PM   #9
rlau1010
Chat Virgin
Of coz its VW Golf Mk4 1.6 automatic
Old 19-11-2012, 10:33 PM   #10
Crasher
Crasher's Avatar
Year and engine code, probably 2000 with an AKL engine or maybe AEH.
