T25 1.9 TD Oil from breather pipe
Hi,
I’ve recently brought a 1.9TD converted T25, and its seems oil is coming out the breather pipe and dripping on the axel, thus covering everything in oil, including the back of the van due to its brick aerodynamics.....
My local garage said it’s just because the engine is slightly leaning over ( to make it fit the engine bay) and they’re not sure what to suggest apart from moving the breather pipe a bit to stop it blowing out so much.
Is this a common problem, or has the conversion just been bodged, anyone know if it’s an easy fix, or a good garage that could sort it or anyone in the TN postcode area that knows what they’re doing want to do it for some cash ?
Or have a brought a piece of s**t problem do you think ?
Would £500 get an engine change if I have, either sticking with diesel or going aircooled.
