Engine case sealer - VW Forum - VZi, Europe's largest VW, community and sales
Old 16-09-2013, 03:39 PM   #1
Dickieboy
Dickieboy's Avatar
Trading feedback: (5)
Default case sealer
Which the best case sealer to use for engines case halves??
Ive been told permatex but which one is the best to use..
I ideally want a paint on sealer rather than a silicon type,as i dont want the same problem i had with my 2007 motor.
Dickieboy is offline   Reply With Quote
Old 16-09-2013, 03:55 PM   #2
Phil69
Phil69's Avatar
Trading feedback: (3)
As long as you keep it on the outer edge of the case sealing face and keep the bead of sealer small (3mm or so diameter) I reckon you will be fine using most silicon based sealers.
Permatex is another good sealer to use as it remains pliable.
Both types have there merits.
GO WITH A SMILE!!:D
Phil69 is offline   Reply With Quote
Old 16-09-2013, 03:59 PM   #3
Dickieboy
Dickieboy's Avatar
I kept the last sealer i used on my 2007 to a small bead and it still ended up in the case (maybe didnt keep it to the outside enough)
I do quite fancy a paint on version..
Which permatex is it i need though phil?
Old 16-09-2013, 04:06 PM   #4
Phil69
Phil69's Avatar
I've never actually used permatex so I'm not sure.
If you decide to use silkaflex you can dispense it using a large syringe (50ml)
This will give you a small enough bead and allow you to control the flow of sealant far better than with a mastic gun.
Hope this has helped
GO WITH A SMILE!!:D
Old 16-09-2013, 04:16 PM   #5
Trav13
Chat Virgin
Trav13's Avatar
The stuff i've always used is a marine type brush on sealer looks like brown snot sticky a hell we use a volvo penta version but i think its made by loctite
Its the best metal to metal sealer i've found never have any problems with it and it allows the surfaces to be tight against eachother
"Loctite gasket sealent 30517"
Trav
Trav13 is offline   Reply With Quote
Old 16-09-2013, 05:45 PM   #6
3901mick
3901mick's Avatar
Elring's Curil T is very good
http://automove.webs.com/
3901mick is offline   Reply With Quote
Old 16-09-2013, 05:55 PM   #7
masterjedi
masterjedi's Avatar
or Curil K2
masterjedi is offline   Reply With Quote
Old 16-09-2013, 08:17 PM   #8
Nessy
I really must get out more
Nessy's Avatar
Trading feedback: (7)
Curil K2 is lovely stuff to use, I recently split apart and re-lubed & re-assembled a newly reconditioned-engine that had stood for a few years, no mess and appears to seal really well.
It doesn't ever harden so won't cause problems like a silicone-type sealer.
The only trouble is getting hold of the damn stuff as the only readily-available source seems to be on German Ebay, so relatively high carriage charges.
'72 1302LS Karmann Cabriolet
'63 Type 1 Karmann Ghia Coupe
Nessy is offline   Reply With Quote
Old 16-09-2013, 08:20 PM   #9
Dickieboy
Dickieboy's Avatar
Yeah ive just found that out trying to get some
Old 16-09-2013, 08:40 PM   #10
Nessy
Nessy's Avatar
I did find a UK supplier eventually, SC Parts (they're Triumph parts people) but they are a right pain as for the last 2 years since purchasing the K2 I've had loads and loads of (unwanted) marketing email from them.
If you do purchase from them don't give them your email addy!
