-   Aircooled Mechanical Tech (https://www.volkszone.com/VZi/forumdisplay.php?f=11)
-   -   [ELECTRICS] Halogen Bulbs for 6V Beetle (https://www.volkszone.com/VZi/showthread.php?t=1588215)
Java Green 21-07-2019 08:14 PM
Can I buy a full set of bulbs - headlights, tail lights and front and rear indicators for a 1965 6 Volt Beetle. I am sure this may have been covered in previous threads but I have recently acquired a 6 Volt Beetle and don't want to convert to 12 Volts. As you can imagine - I can't go out at night and nobody can see my indicators during the daytime (lots of angry Chelsea Tractor drivers) and I am having to wind down the window and use hand signals. Any advice would be much appreciated. Chris.
clarkson 21-07-2019 09:14 PM
It is going to be caused by voltage drop in old wiring. You can have the best bulbs in the world but if they aren't getting any volts they won't work.
Big Al 21-07-2019 09:49 PM
This looks a good site
https://www.classiccarleds.co.uk/col...ight-led-bulbs
Found this website which looks interesting. Not read it all mind.
http://www.dynamoregulatorconversion...boards-etc.php
Bike site
http://www.norbsa02.freeuk.com/goffyWhyNotLEDs.htm
Java Green 21-07-2019 11:15 PM
Thanks Clarkson and Big Al - much appreciated.
Mr.Whippy 22-07-2019 09:32 AM
As well as the voltage drop issue there is often a problem with the old reflectors on these cars. If you look into the reflector bowl you should see a sharp reflection of yourself like looking into a mirror. If the reflection looks hazy or foggy then you won't have a good beam pattern and your headlights will be terrible no matter what wattage bulbs you use or how good your voltage is. You usually can't polish the reflectors because the silvering (it's not chrome) is very thin indeed. Replacement with new is the only real world solution to get good headlights if your reflectors have seen better days.
However if the other lights are also dim then you probably need to address the voltage issue first.
Also, if you have indicator bulbs inside sloping headlights, these can be very difficult for other drivers to see when the headlights are on. A bad idea really.
It is just possible that a P.O. replaced the bulbs with 12V ones mistakenly so worth inspecting them closely when you remove them - most bulbs will be marked with the voltage somewhere.
ainokea 24-07-2019 02:21 AM
You might also check each light fixture's ground circuit. Clean down to bare metal, make sure the wire connector is clean. Most people usually do not consider the ground circuit taking it for granted that it is not a source of resistance. Solid grounding is as important as is positive current.
gojira 24-07-2019 11:42 AM
to check the wiring with a multimeter - turn them on and backprobe each lamp to see what voltage they're seeing. then check voltage from the battery + to lamp +, and lamp ground to battery -.
that'll tell you how much you're losing and whether its through the switches, earth or both.
Java Green 25-07-2019 11:12 AM
Thanks to all for your very practical advice - I will follow up on all - Chris
Bobdisk 02-08-2019 07:24 AM
Mr Whippy is correct about headlight reflectors. If they are otherwise in good condition, and you do not want to replace them. Try these I have no experience of them, but they look good. (for more, just Google "re silver headlamp reflectors"
http://www.ashfordchroming.com/headl...ng-restoration
https://chromeplatinginuk.wordpress....t-resilvering/
Its not cheap, but you do keep originality.
jonnyfive 09-08-2019 02:21 PM
Worth a watch:
https://www.youtube.com/watch?v=Azcfhf2hQB8
