-   Alternate Engine (https://www.volkszone.com/VZi/forumdisplay.php?f=51)
-   -   Fuel Ppump set up (https://www.volkszone.com/VZi/showthread.php?t=1589049)
eugopnosaj 30-08-2019 03:38 PM
Fuel Pump set up
So I run both a facet pump and and a bottle bottle style pump; tank - filter - facet pump - swirl pot - bosch pump - engine.
The facet pump is noisy by nature but it is so loud I was looking to replace this with a pull style pump.
I have done a search on here but it hasn't come up with anything concrete, now that a few people have had their conversions running for a while what set up do you guys have for your fuel systems? :)
atlas2l8v 30-08-2019 10:27 PM
I'm running the subaru legacy one mate. I cut into the beetle tank and baffled it, and welded the flange for the Subaru intank pump to be used
eugopnosaj 02-09-2019 02:58 PM
Ah the donor car has long gone :lol: and I wasn't inclined to cut my tank up, although that would have been the better option. Are you just using the 1 pump? You can get golf mk2 digifant swirl pots which have a built in pump, although theyre in excess of 100 to buy. As standard these would have been fitted underneath the car, along with the filter but they still have an in-tank pump. My corrado (in 16v form uses mk2 parts) had the same set up only it used an external pump with the swirl pot but still 2 pumps, I think my VR6 is similar, not that it helps but they both use 2 pumps.
Big Al 04-09-2019 09:06 AM
I got a good....ie expensive...aftermarket rotary pump which is fitted the the petrol side of the kick panel. Fed from an 8mm outlet I diy soldered tho spotted this today
https://www.volkszone.com/VZi/showthread.php?t=1587203
Used a stock scooby filter at the back of the car which I need to move as hard to access, it's a big bugger and then my return lines feed into the bottom of the fuel filler. There was an outlet so I just used it. Would be better lower but do for now.
No swirl Pot. No baffles. 13.1. No fuel starvation....yet :)
Big Al 04-09-2019 09:09 AM
I just had an idea. I wonder if putting the tank on a slight slant (I would have said cockel but you wouldn't know what I'm talking about, you know....Cockel it!! :lol:) would cause any cleanace isues and if might help keep fuel at the outlet under hard acceleration. Like said not been a prob yet maybe had too much fuel in but just a random thought.
Obviously fuel couldn't be allowed to go as low but I'm not talking 90 degrees!
booton 05-09-2019 09:48 AM
im running an impreza one in the tank. ( like other my tank and donnor cat tank was cut up and made beetle tank with the pump and return line floats. )
it is fairly noisy to but some sound proof could easily cover it.
eugopnosaj 06-09-2019 02:45 PM
That's a good way of increasing it, never thought of that. I just fitted a different insert into the nut that fitted on the bottom of the tank then used 90 degree adaptor to change the orientation but this might be better.
I would insulate the pump but I think cooling might be an issue if I wrapped it or put it in a box. It's not too bad under load, but on idle it just a continuous sound, as if someone was rolling their "R's" non-stop :lol: and sounds a bit, pathetic. Unfortunately I have neither a spare tank, nor the subaru in tank pump to modify. I wonder if I can get a bigger swirl pot (currently 1ltr) and modify that to fit an aftermarket in tank pump, then use the Bosch style one to feed the swirl pot? (I know you can buy them but the one's I've seen are competition ones and large/expensive!)
Also what FPR are you guys running, I'm just using the standard one on the engine.
Big Al 10-09-2019 09:27 PM
I haven't used an fpr. I figured excess would just go back to the tank. Mine is noisy even tho its rotary tho when the engine is running it's so loud in my car I don't really notice it any longer. It had a sponge jacket with it so just d clamped on as was.
