Engine Carburettor expert advise needed - Page 7 - VW Forum - VZi, Europe's largest VW, community and sales
Old 18-02-2019, 11:31 AM   #61
GARRICK.CLARK
GARRICK.CLARK's Avatar
If the piston/slide lifts too fast under excel it will create a flat spot. On an S.U... IF there is a flat spot it can be fixed it with a thicker oil in dashpot or a stronger spring. Your carb will have a spring in the top holding the piston down. Try lifting the piston there should be resistance. So see if you can find a stronger spring. If you cant find a stronger spring you could make the piston/slide heavier.
So. If the piston/slide rises to fast too much air will go into the engine creating a flat spot
Aircooled mechanic
GARRICK.CLARK is offline   Reply With Quote
Old 18-02-2019, 03:47 PM   #62
sallyandsean
sallyandsean's Avatar
Originally Posted by GARRICK.CLARK View Post
If the piston/slide lifts too fast under excel it will create a flat spot. On an S.U... IF there is a flat spot it can be fixed it with a thicker oil in dashpot or a stronger spring. Your carb will have a spring in the top holding the piston down. Try lifting the piston there should be resistance. So see if you can find a stronger spring. If you cant find a stronger spring you could make the piston/slide heavier, so long as its heavier.
Brilliant, that makes sense
sallyandsean is online now   Reply With Quote
Old 19-02-2019, 07:39 PM   #63
sallyandsean
I have had a look to see if they do a heavier spring but can't find anything. What would you suggest to use the weight the piston and how much weight woukd you recommend? Cheers
Old 20-02-2019, 10:31 AM   #64
Leigh d
Could you put a shim on one end of the spring. That would put more tension on the spring. But may also cause it to go coil bound before it should.
Leigh
Leigh d is offline   Reply With Quote
Old 20-02-2019, 11:01 AM   #65
sallyandsean
Leigh
Good idea
Old 20-02-2019, 03:08 PM   #66
GARRICK.CLARK
As leigh says really. try fitting a round disc inside the piston/slider. I take it.. it's the same as the su piston were the piston is hollow and the spring slots inside it. If so fit a round steel disc into the piston to weight it down . The weight of it is a guess thing,you might have to increase it or reduce it.
Aircooled mechanic
Old 28-03-2019, 03:06 PM   #67
sallyandsean
After a lot of messing I now have it running.
https://youtu.be/sO1uL70sTDU
Old 28-03-2019, 06:52 PM   #68
GARRICK.CLARK
Is it running good.
Aircooled mechanic
