Brakes Home-made brake caliper tool - VW Forum - VZi, Europe's largest VW, community and sales
Old 23-08-2012, 01:42 PM   #1
smoggyrich
smoggyrich's Avatar
Default Home-made brake caliper tool
Doing my Brakes soon so I've knocked up a caliper piston retractor...
Just need to weld the fixed nut and the guide/slide in place.
I'll let you know if it works
smoggyrich is offline   Reply With Quote
Old 23-08-2012, 02:01 PM   #2
evilC
evilC's Avatar
I just use a big screw driver or tyre lever
evilC is offline   Reply With Quote
Old 23-08-2012, 06:31 PM   #3
wastedspark
wastedspark's Avatar
Tyre lever or G clamp for me, posh git
Turbo buggy build
splity project
wastedspark is offline   Reply With Quote
Old 23-08-2012, 08:06 PM   #4
keithski122
keithski122's Avatar
Big pair of grips.
keithski122 is offline   Reply With Quote
Old 23-08-2012, 10:04 PM   #5
al_kaholik
al_kaholik's Avatar
Trading feedback: (23)
Good effort - I bought one but if those bits were lying around then you've saved yourself a little
A supporter of "perfection through inspection."
Wasserboxer conversion
'77 Jap import FI and Aircon
al_kaholik is offline   Reply With Quote
Old 24-08-2012, 12:15 AM   #6
smoggyrich
smoggyrich's Avatar
I made all the parts from off-cuts lying about at work. I used the lathe to turn the parts.
My motto... "Why buy when the company supplies?"
Plus i was getting payed at the same time
Dont tell the boss!
Old 24-08-2012, 10:10 AM   #7
evilC
evilC's Avatar
Not wishingbto piss on your achievement but the flat plate looks a little weak to me because most times that I need someting more than a lever is because the pistons are a lttle siezed and I could see the plates bending, which will mean that you will be trying to push the piston back in on one edge only. Do the workshop tool suppliers use high tensile or tool steel for the plates?
I have never been tempted to buy one of these tools because I can't see the value of them
Old 24-08-2012, 10:36 AM   #8
smoggyrich
smoggyrich's Avatar
It's 6mm plate so i think it shoul be ok.
If the pistons were siezed i would imagine that you would want them to come the other way (out) so that they could be cleaned up and new seals fitted.
Last time i had to get pistons out i fitted a grease nipple to the back of the caliper and pumped them out with a grease gun.
The tool will be used simply to push the (un-siezed) pistons back so that new pads can be fitted.
You may think it's a bit of over engineering but i think it's a handy tool to have to make sure the pistons are going back in square/level.
Plus it didn't cost me a penny. In fact i was getting payed when i made it.
Old 19-10-2012, 08:21 PM   #9
smoggyrich
smoggyrich's Avatar
Well I have done my front brakes and my tool worked a treat.
I was just going to buy a rewind tool off ebay for my rear brakes, but then i thought, where's the fun in that?
So......
I can screw back 2 of the 6mm allen bolts depending on which pitch I require.
I think this should do the job.
Old 19-10-2012, 10:13 PM   #10
64woody
64woody's Avatar
Plus it didn't cost me a penny. In fact i was getting payed when i made it. [/QUOTE]
I had a job like that, count yourself as lucky and look after it.
64woody is offline   Reply With Quote
