If you're gonna make a special, make it special - Page 44 - VW Forum - VZi, Europe's largest VW, community and sales
Old 30-10-2019, 12:16 PM   #431
Has the shifter got the pin in the ball and the slot in the shift linkage? My 70 doesn't. The chromed angled shifter i wanted to use rotates so i sold it again and went back to a straight one again.
I ended up making a quick shift for my bug using a bay window shifter bottom housing and shift plate and the mushroom from the cheap quickshift kit. Looks stock but reduced throw nicely.
Old 30-10-2019, 12:24 PM   #432
dc66
dc66's Avatar
Yes it has the pin in the ball.
At some point I'll get one of those fancy high end shifters, but for the moment I can't afford one.
dc66 is offline   Reply With Quote
Old 25-11-2019, 03:56 PM   #433
dc66
dc66's Avatar
At last! I have started on the body! Whoop whoop!
Starting with the scuttle panel and the instrument binicle.
Stretching out the area so the metal moves upward. It put in the wheel inside down so the metal follows the curve of the lower wheel.
Old 25-11-2019, 04:05 PM   #434
dc66
dc66's Avatar
Once the shape is in, I back off the pressure between the wheels to focus on getting a nice even finish.
This panel will be welded into the scuttle panel once that's made. The top will roll over the steel tube to form the top of the dash. I'll do that bit last of all.
Old 25-11-2019, 06:20 PM   #435
pedalcarjoe
Trading feedback: (13)
great news
pedalcarjoe is offline   Reply With Quote
Old 26-11-2019, 10:10 AM   #436
skip*rat
skip*rat's Avatar
Excellent work
more please !
Especially English wheel techniques
And transfering to buck
skip*rat is offline   Reply With Quote
Old 26-11-2019, 01:43 PM   #437
Brownpantsracing
Brownpantsracing's Avatar
Trading feedback: (4)
I have so much respect for your skills.
Actually has a classic VW on the road again! Woo hoo. Oh hang on.. it's broken again. >:(
Brownpantsracing is offline   Reply With Quote
Old 27-11-2019, 08:40 PM   #438
dc66
dc66's Avatar
I've left the rest of the scuttle for now. I'm focusing on some of the tricky parts first. At the moment I'm sharing a workshop with my old boss. He's a master with the English wheel. Shortly I'm moving to my own workshop, so I want to have his advise on hand for these tricky parts!
Next I'm making the front wings. First the gully between the wing and the bonnet.
A strip was cut out and then pulled over a tube. To make it curve round the shape of the buck I stretched the edges on the wheel.
Old 27-11-2019, 08:47 PM   #439
dc66
dc66's Avatar
More stretching
As it gets the shape I've put the top edge through the shrinker to "tip" the edge so it will flow into the top of the wing.
From the underside you can see it follows the buck fairly well
Old 27-11-2019, 10:08 PM   #440
76
All looks pretty easy
Or should that be you make it look easy
Looking good, keep up the updates, very interesting to watch/read.
76 is online now   Reply With Quote
