Little Horus VWDRC build - Page 9 - VW Forum - VZi, Europe's largest VW, community and sales
Old 13-04-2019, 10:25 AM   #81
runningmonkey
I really must get out more
runningmonkey's Avatar
Originally Posted by type3 View Post
I think that’s a great number off the bat at 8psi!
I think American dynos are a bit ‘generous’. Also those engines in the other vids are probably running higher boost?
Add 15% to convert to fwhp.
True, they are generous when it comes to HP I have just released that all the videos on the CB performance website are also done at the flywheel/crank, and at much higher boost. Their 2332 is make 290 at the flywheel at 14PSI, so at the wheels that would be around 230 to 240ish. So with mine running 171 at the wheels at 8PSI its not to far from them numbers.
20190410_191047 by John Mills, on Flickr
Iv just fitted a boost controller, Its set to neutral at the moment so we will still run 8psi this weekend, and up it to say 12 psi and see how we go.
My 1956 Oval Drag beetle Little Horus -
https://www.volkszone.com/VZi/showthread.php?t=1189194
runningmonkey is offline   Reply With Quote
Old 13-04-2019, 10:25 AM   #82
runningmonkey
Video of the dyno run
https://www.youtube.com/watch?v=DZjVh2dO2so
Old 13-04-2019, 11:28 AM   #83
type3
type3's Avatar
Trading feedback: (10)
Originally Posted by runningmonkey View Post
Excellent!
Will you need to get it re-dyno’d at the higher boost? Or will the CB setup handle the additional fuelling?
type3 is online now   Reply With Quote
Old 23-09-2019, 04:52 PM   #84
runningmonkey
Time for an 2019 end of season update and its long one (sorry!)
So where did we get to?
Our first racing meeting after our dyno run was festival of power, I was hoping for big things and get the car easily into the 12’s...but it wasn’t to be. Ever since I fitted the bugtech shifter Iv been having trouble getting the car into second gear and my first run was no different, missed second and rolled over the line at 14.25 @ 94.86, however I did do my best ever 60ft time of 1.59 which I was pleased with. Second run can had no power and we never made a third as the engine developed and loud noise from the case and we retired the car.
20190420_165239_HDR by John Mills, on Flickr
I sent the engine up to Daz Chandlers for inspection. It turned out the engine had an oiling issue and it killed the crank! As you know, am crazy unlucky and this was a new build motor. Anyway, I won’t point fingers or say anything else other then its was back to the drawing board yet again. After a few chats with various engine builders it was decided we were going to rebuild the motor again but this time to a 2276cc (I have had a lot of conversations with folks about 2332cc motors and most agree that the extra 56cc you gain using the 84mm crank really is completely pointless as the 84mm cranks are just far to weak) The cam was also wrong for my turbo setup in the 2332, so that was changed from FK87 to FK10. I only needed a new cam, crack and followers so the cost to repair wasn’t the end of the world. (but still…)
61763447_2392998387642425_8375235460410114048_o by John Mills, on Flickr
61871495_2392998424309088_7023751450136150016_o by John Mills, on Flickr
I had ordered a set of M&H slick from Track stuff in the winter which had now arrived, Never ran slicks before so these should be fun.
64836399_2403969719878625_2457075168552419328_n by John Mills, on Flickr
I got the engine back from Daz in July 2019, and everything was refitted, and we were up and running in time for VW action. (Minus the charge cooler as it wasn’t cooling the charge anyway) Then more bad luck… We were ready to run at Action when the fuel pump kept blowing fuses, We spent the day trying to find out why, and eventually located the problem. We removed the fuel filter to clean it found out that it was full of rubber! The new fuel line that I had installed in the new year had completely disintegrated! (bought from ebay) Long story short, the rubber had somehow managed to bypass the filter and got everywhere, destroying the fuel pump, fuel regulator, and damaging the injectors! So we returned home broken again.
70235077_2458027624472834_4014066766870216704_o by John Mills, on Flickr
BROKE AGAIN!
After more nights in the garage, and replacing all the fuel lines (this time with more expensive demon tweeks fuel line) it was time for Nation finals
First run and I missed second gear again! However did an even better 60ft time @ 1.53!!! Really pleased with that! So I've decided it was time to swap the bugtech shift out and replace it with an old Hurst shift I had (Bugtech shifter its cool as hell but I just can’t live with it) Second run was better and the car pulled a really nice wheely, 3rd run of the day was also good, good pulled strong (another great wheely!) and we ran 13.1 @ 104mph Happy with that. On Sunday we were going to turn the boost up and really give it some beans! However it rained all day and we didn’t get the chance to run.
It's now the end of the season and we have a running car, which can only improve over the winter...watch this space
70643285_2474045852871011_3212526410878943232_o by John Mills, on Flickr
71771498_10157506421328149_5330762465464549376_o by John Mills, on Flickr
WHEELY TIME!
Will put a video up with some of the runs when I get time to do an edit.
Old 23-09-2019, 08:40 PM   #85
76
BROKE AGAIN!
WHEELY TIME!
Good update, that final picture is wheelie cool
See what I did there^^^
76 is offline   Reply With Quote
Old 24-09-2019, 01:47 PM   #86
Brian Burrows
Older
VZi Member Sponsor
Location: In the middle of someone's 'story' . . . mostly
BROKE AGAIN!
WHEELY TIME!
Thanks for the update dude.
Be lucky.
Brian Burrows is offline   Reply With Quote
Old 24-09-2019, 01:49 PM   #87
Brian Burrows
Older
VZi Member Sponsor
PS: A load of the VWDRC guys are coming to play at GTI Festival on October 6th - you're most welcome.
Old 23-10-2019, 11:17 AM   #88
Guest
Default Coil Over Rates
Made 150 on the rollers
521582_10150742042481294_876792098_n_zps46046e3c - Copy by John Mills, on Flickr
At cal look (the stinger is a new addition and got me into the 12's just)
P1020285_zpsa425779a by John Mills, on Flickr
And the car today (well last week)
10635883_10152610304666294_3409596990643629520_n_z ps6be7f5bb - Copy by John Mills, on Flickr
Best time to date
10346461_10152435735151294_3772276272919564297_n_z psaa28f719 - Copy by John Mills, on Flickr
Best time over the years
2009 14.99 @ 88MPH
2010 13.87 @ 94.5MPH
2011 16.30 @ 80 MPH (Slipping clutch)
2012 -Broken-
2013 13.27 @ 100.61 MPH
2014 12.87 @ 103.24 MPH
So that's the past here the future, over the winter am going to be taking the engine out and getting a cage fitted and tied into the frame horns, I may up the cc from 2180cc to 2276cc but will have to wait and see
HI interested to know what spring rates you are running on your Coil-overs???
Guest is offline   Reply With Quote
Old 03-11-2019, 08:03 PM   #89
runningmonkey
No idea! I got them second hand so not to sure sorry.
OK folks Iv just finished part 5 of my you tube project about the car. Its the best one yet (my video editing skills are now getting awesome!)
Click on this link the view part
https://www.youtube.com/watch?v=_kzST_4pmpM
Old 10-03-2020, 10:42 PM   #90
runningmonkey
Evening folks
I have a small update and like last time its in the form of a YouTube video!
This is now part 6 -
https://www.youtube.com/watch?v=PAJkaa5jfVE&t=230s
As the car was running at the end of last season, Iv not had to much to do over winter. One upgrade I have done is installing water methanol cooling. If you remember from the previous videos and if you have been keeping up with this thread, you will know that the charge cooler wasn't working and I couldn't get it the cool the charge. Iv now got rid of the complete charge cooler setup and gone down the water/meth route. I will have the car back at the dyno in the next few weeks ready for the start of the season, so I will make a video about that to. But for now please enjoy part 6.
