PUG the 1303 eBay bug - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Old 16-03-2017, 11:02 PM   #11
iain ambrose
iain ambrose's Avatar
Nicely done
Old 17-03-2017, 07:44 AM   #12
skip*rat
skip*rat's Avatar
Cheers it's not going to be pretty but i quite enjoy trying to resurrect old bugs
Past 30 years had a few beetles most of them would now be described as rat look but i just done everything on a budget 😁
Old 17-03-2017, 08:08 AM   #13
StuF
StuF's Avatar
Great work - looks like a fantastic find!
Where Napoleons armies marched with horse and musket and Hitlers Reich crumbled in blood and rubble, the warriors of Armageddon do battle against the landscape of hell now indeed thrive the ARMOURERS
Weekend - 1970 Type 2 EJ25 Powered 5 Speed EarlyBay on BTR's
Fun - Silver Porsche 996 Turbo
Inclement - Silver Porsche Cayenne Turbo S
StuF is offline   Reply With Quote
Old 18-03-2017, 09:19 AM   #14
skip*rat
skip*rat's Avatar
Drivers side similar condition heater channels will repair closing panel needs a couple of small repairs.
Removed door i prefer to use my welder to remove the seized hinge screws to avoid disturbing hinge plate position with impact drivers as force.
Lower screw drilled into head and welding built up until mole grips can be used to remove.
Same at top but nuts used as easier to access outer screws
The heat almost instantly breaks rust bond and the screws are removed with a socket while glowing!
Old 18-03-2017, 09:26 AM   #15
skip*rat
skip*rat's Avatar
Obviously this ruins the screws but whole process took about 20 minutes
Hot screws 😁
Old 18-03-2017, 09:41 AM   #16
skip*rat
skip*rat's Avatar
So basically I'm very tight and if i can make something heath Robinson style i will !
Flywheel oilseal gave out and i did remove the nut with a breaker bar and angle iron combination but when it came to tourqeing back up i liked the idea of a torque multiplication tool but these are £100
So made one
Had a knackered starter knocking about stripped the main shaft down
Reversed the cog and welded it to end of shaft
Then welded bar to old socket
Had this socket welded to an old elora ratchet handle to remove hub nuts with a ten foot bar!
Measured on flywheel and tacked together
I had more pictures but phone died and took most of my pics with it!
Anyway after a proper full power welding session it works perfectly multiples by 9 so i can accurately forge nut with my 1/2 inch torque wrench and cost nothing 😎
Old 18-03-2017, 11:48 AM   #17
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Nice homemade torque multiplier tool.
I found this site a while ago. Some great stuff to build.
http://www.homemadetools.net/
1970 1300 Beetle resto here
1970 1300 Beetle part 2
Old 18-03-2017, 11:58 AM   #18
skip*rat
skip*rat's Avatar
Cheers Zebedee looks better now fully welded but its in my drawer at the workshop so no pics
Checked out the website link like the idea of diy plasma cutter !
Old 18-03-2017, 06:29 PM   #19
Zebedee
Zebedee's Avatar
Ooh, i must have missed that one.
Old 06-02-2018, 07:25 PM   #20
skip*rat
skip*rat's Avatar
Havenít had chance to work on car for 4 months,and What with the demise of my I phone and photobucket fiasco Iíve lost quite a few pictures
But done a little bit more
At first inspection drivers side rear body mounts looked pretty good never plated up.
But after a few taps with my trusty toffee hammer
Itís all a little rotten! Now I had intended to just plate it up but that much corrosion had to be done a little better than just covering up.
I have been buying beetle panels at shows when I see them cheap just in case...
Trial fitted whole panel with Cleco fasteners then Un spotted the rear body mount so I could repair the boot floor and return lip first, then fix body mount reinforcement plate and body mount.
More rot
Had a right side outer rear cross member section in my little stash and it was a good pressing so used this to set up panels.
