Devon Eurovette (Bluebell)rolling resto - Page 8 - VW Forum - VZi, Europe's largest VW, community and sales
Old 13-10-2019, 10:24 AM   #71
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Looks like its coming along nicely.
Its always the little bits that take the longest.
1970 1300 Beetle resto here
1970 1300 Beetle part 2
Old 23-10-2019, 10:37 PM   #72
beetlebobby
Default bits done
Been busy for last week and weather a bit naf but have done a bit of moving around with silvia (beetle)in her temp council garage nice and dry to which is a bonus,,,, got those lamps made back up only one spring to replace as rusted beyond repair and grill all dry and looking great,,,,Went around van armed with some duct tape and covered all the possible sharp edges so i could fit the winter cover on which did fit very well,, thanks to just campers not the cheapest one but had the £30 off deal going on so worked out at £100,,Also removed both front doors and rear hatch which is what im going to be concentrating on over winter now with the garage door shut and heater on,,, nice and toasty.busy for next week so catch ya in a few weeks.
ID:	270355   Click image for larger version
beetlebobby is offline   Reply With Quote
Old 03-11-2019, 09:10 PM   #73
beetlebobby
Default bits done
Ok so thought id tackle the rear tailgate as there doesn't seem too much rust to deal with only one main bit at the bottom and a few small holes where the window popped out,,,, so cut out rusty areas made a few repair pieces and welded in place,,ground flat ish and stripped rest of door which seems fine although not as flat as you would like so knocked out best as possible and a skim of filler will hopefully get her somewhere flat(although shes curved) well you get the point!!,,obviouly i treated areas with some rust killer and rust eating properties then a coat of red oxide under patches,,, managed to get a thin wire brush behind bottom of skin as there was more surface rust and a drop of the rust killer poured over preventing further rusting well for a few months,,,i will give it a dose of waxoil before i put panel back on,,, hopefully do a bit more tomorrow if time permits..
ID:	270599   Click image for larger version
ID:	270601   Click image for larger version
ID:	270603   Click image for larger version
Old 03-11-2019, 09:13 PM   #74
beetlebobby
Default more pics of todays jobs
more pics
ID:	270607   Click image for larger version
ID:	270609   Click image for larger version
ID:	270611   Click image for larger version
Old 06-11-2019, 06:11 PM   #75
Zebedee
Zebedee's Avatar
Nice repair.
Old 12-11-2019, 10:11 PM   #76
beetlebobby
Default bits done
Cheers zeb glad someones likes it!!!!
this week ive had a couple of hours on the rear hatch,,,managed to get the front quite good so flipped it over and worked on the rear which had a dink in so filled it as couldnt get behind to knock out and didnt fancy drilling holes in to pull out with a self tapper,,,,
Ive purchased some epoxy primer which im told is the best thing since sliced bread at protecting bare metal,,so after getting panel ready over last day or so i managed to get a good coat of primer on,,,also brought some panel wipe to help with getting it clean,,
so will leave this to dry and then put a few coats of normal primer before the rustoleom gets a look in,,,
ID:	270809   Click image for larger version
ID:	270811   Click image for larger version
ID:	270813   Click image for larger version
Old 12-11-2019, 10:12 PM   #77
beetlebobby
few more
ID:	270817   Click image for larger version
Old 13-11-2019, 05:50 PM   #78
Leigh d
Nice work. Can I ask what primer you went for been doing some looking into epoxy primers, as plan on starting restoration next year.
I take it thatís from a gun not a rattle can.
Leigh
Leigh d is offline   Reply With Quote
Old 14-11-2019, 09:32 AM   #79
beetlebobby
Default stuff
Hi Leigh quick reply before i venture into garage i used the HB Body Vehicle 989 primer,,,trev from youtubes trevs blog used it without complains so if its good enough for him!!! also i put 10% 2k thinners in with it and shot it out of a cheap touchup gun as its only a small panel and didnt want too much over spray.
PS check out trevs blog as he the dogs danglies at restoration.
Old 16-11-2019, 06:00 PM   #80
Leigh d
[QUOTE=beetlebobby;16572525
PS check out trevs blog as he the dogs danglies at restoration.[/QUOTE]
Some good watching there must watch some more cheers
Leigh
