Hi, I am selling my CSP Twin Quiet pack which I have taken off of my 1641 engine with a twin carb set up. Am I right in think that it will also work with a single carb set up?
Cheers
I'm not sure if it helps as it wasn't the Csp brand. But I used to run both single and dual quiet pack exhausts on my bug. The sound from that setup was very similar between the exhausts though the dual was less restrictive. (For a stock motor I doubt would make a lot of difference, for something built to breath the single can be too restrictive)
Unless the manifold has the flanges for the inlet manifold pre-heat tubes then it won't be suitable for single carb engines. I mean it'll still work but the owner will probably have cold running issues in the colder months.
Related Threads
Volkszone Forum
7.1M posts
80.5K members
Since 2003
A forum community dedicated to aircooled Volkswagen owners and enthusiasts. Come join the discussion about performance, restorations, modifications, classifieds, troubleshooting, maintenance, and more!
