Items For Sale - AUTO Private sales only please. Commercial and 'regular' sellers, please take a banner advert or become a Member Sponsor and support the site before running your 'business' or 'just selling' through VZi. VZi Classifieds were originally set up as a 'free to use' facility for the members who contribute with threads and replies in the Mech Tech, Chat and Readers Rides forums etc. As VZi has got bigger, we see more and more new Members who ONLY ever post in the Classifieds and contribute nothing (neither monetary nor in content) to the forums. This is fine, however to use our facility this way you will need to become a Member Sponsor. Become a Member Sponsor here. Please read the sticky threads BEFORE posting - it may save you time in the long run. Forum available for sponsorship
Forum sponsored by:
www.OnlineCARparts.Co.Uk |
06-11-2019, 07:03 PM
#1
VZi Member Sponsor
Parts, parts, parts...inc Performance, rare, N.O.S.
Hi
All prices plus post unless stated......paypal gift or please add fees. Please check through thread as new parts continually added.
Beetle
N.O.S. Offside oval rear light housing 61-67 & 1200 VW stamped £50
Motometer oil pressure gauge with correct fitting for gauge and to sender £75
N.O.S. VW boxed 3 rivet camshaft (nothing better for stock build) £195
Engle FK89 cam- never fitted and clearanced £100
N.O.S. 67 Bonnet handle £85
Complete 67 Beetle lock set, both door handles, ignition switch, decklid lock plus bonnet handle including inner and also door latch mechanisms with correct lock pull and inner chrome handles
N.O.S. VW OEM 25/30 hp Fuel Pump diaphram £55
3 x 25/30 hp Original VW Fuel pumps- varies on year you require
1 x early pump pedestal, VW stamped
N.O.S. 61-66 Door handle- drivers side with 2 keys, stunning £245
N.O.S. Cabriolet Bonnet lock/ pull handle with housing 61-66- can be used on other years but key codes correct for 61-66 £245
Super rare Dealership parts book- bible for part numbers, colour codes etc- Not sure what this is worth but really no silly offers
New boxed ATE twin circuit master cylinder (LHD) £155
New KYB GR2 ball joint front shocks £80
CSP LHD shifter, new in packet. T handle with button and angled shaft so pre 67- £195
1302/3 front brake drums. New boxed £60
Proper old stock Boxed Bosch sloping headlight lenses 61-67 £140
New King/ link pin Beetle disc drop spindles £95
Original Weber stamped 32/36 manifold section, much better than modern copies- £75
Rare 68 only Air filter- this has the twin inlet like 67 but single pre heat inlet £85
Also have matched pairs of headlights for 53-55 and 56-59 Ovals, Beetles £varies
Original VW overriders for blade bumpers VGC but not perfect set of 4 £200
2 sets of pre 67 sidetrim added, one set Original VW- see post 6 below
06-11-2019, 07:04 PM
#2
VZi Member Sponsor
Split, Baywindow
Pair of matched Hella 1955 Split headlights- extremely rare as all parts inc rim, buckets, reflectors have part number and Hella stamp visible £POA
Pair Avis Adjusters Baywindow 68-79- Look similar as ones Limebug sells but these have been in spare room for over 5 years so teeth cut well and parts interlock nicely £75 inc UK post
71-72 NEW Crossover front discs- best German quality made by SEBRO £140
Pair of Latebay disc spindles- perfect for converting crossover bays to the bigger calipers, pads. Calipers also much cheaper and more readily available £100
Original ZF LHD Latebay steering box- great condition with no play, includes mounting plate, bolts and special nut, washer for drop arm. Much better than modern repros and getting rare to find £350 OBO
T4 case see under Porsche
T4 96mm Old stock NPR 96mm Barrels & Pistons- far better quality than modern AA etc. Asking £675 and delivery only to Slough.
T4 Scat H beam rods 5.325 for stroker cranks 22mm pin £315
T25
T25 1.6D New AMC cylinder head (will fit Golf 1.6D). Asking £475 saving nearly £200. Think this can also be used for 1.6TD but please check
06-11-2019, 07:13 PM
#3
VZi Member Sponsor
Ghia
67 Speedo, fantastic condition
Porsche
914 engine case- can be used for T2 builds with a few mods. This is the sought after case as fuel pump blocked in factory and no pump pushrod tube to deal with. Checked by machine shop and spot faced on barrel mating surface £450
Original Porsche 911/ 912 400mm steering wheel, 70s era
2 pairs of Original Porsche 67 911S 4.5J Fuchs
General
N.O.S. Boxed VW 25/ 30HP main bearings From £110 set
Bosch 009 dizzys (not repro) £50
N.O.S. Boxed Passat B1/ Audi 80 B1 Fuel gauge £50
07-11-2019, 08:50 AM
#4
Hi how much for the lhd master cylinder at slough please? is it new ? Used? Rusty ? Cheers dan
11-11-2019, 02:09 PM
#5
VZi Member Sponsor
Original Beetle blade bumper overriders added.....
18-11-2019, 08:06 PM
#6
VZi Member Sponsor
Pair of Latebay disc spindles added.
Also have 2 sets of Beetle side trim- first set is an old repro set purchased back in 1994. This is for pre 63 Beetles with the shorter bonnet trim and badge. Much better fitment than the latest available, near perfect £65
Second set is for 63-66 Beetles as has the longer bonnet trim. This I believe is original VW as has correct curvatures in all pieces and some side trim pieces have special shaping not on repro. There are some scratches etc but find another original set £135
21-11-2019, 02:08 PM
#7
VZi Member Sponsor
Set of original VW front and rear door cards from a 72 Beetle. Finished in dark royal blue although door handles are black but seem original.
Includes correct door mounting bracket behind handle, door pocket in drivers panel andcash tray in rear panel.
Also have matching blue kick panels for under rear seat. Asking £110 for the lot, in very good condition with only a few nicks.
03-12-2019, 07:01 PM
#8
VZi Member Sponsor
Up.......
Thread Tools |
Display Modes |
Linear Mode
Disclaimer: For recreational purposes only, some assembly required. Any resemblance
to real persons,
living or dead is purely intentional and the site admins are not responsible
for direct, indirect,
incidental or consequential ridicule resulting from any defect or failure to
perform. No animals
were harmed in the creation of this forum. Colours may fade over time. No other
warranty expressed or implied.
Supporting
