Engine T25 engine upgrades. - Page 6 - VW Forum - VZi, Europe's largest VW, community and sales
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Old 11-04-2013, 06:49 PM   #51
jhon2586
Chat Virgin
Hello and welcome - have you looked in the WIKI yet? or the first post in this section on diesel engine upgrades?
good choice on upgrade option, you will need a few bits however...
the sump on the 1.7D (KY?) doesn't have a turbo oil return connection - you can get a JX (1.6TD) sump or a kit a brickwerks to tap your existing sump
exhaust manifold and turbo arrangement may not work - could foul the nearside engine mount or stud pattern may not be the same (check - there are 3 or 4 stud types i believe) some people use a JX exhaust manifold here too. not sure about upgraded turbo, my standard aaz one is fine.
exhaust fabrication might be required if you're swapping turbo's etc. ideally something 2" and straight through is what you want, can use a JX setup if needs be but your 1.7D will not cut it
If the 1.7D inlet manifold is anything like my old 1.6D then you will need a JX setup here too
2013 MERCEDES BENZ SL-CLASS
jhon2586 is offline   Reply With Quote
Old 19-11-2013, 09:08 PM   #52
wilber71
Chat Virgin
Hi Spanner boy....you have been recommended to me from a few people on FB T25 forum...I am after a quote for doing a Subaru 2.5 conversion on my T25 water cooled caravelle please. What is a rough guess for this to be done if I supply motor and wiring etc ? Is the 2.5 a good one to do ? Or would you recommend another option..thanks
wilber71 is offline   Reply With Quote
Old 13-08-2014, 09:40 PM   #53
woodguru
Chat Virgin
Originally Posted by SPANNERBOY View Post
I am just finishing an auto at the moment,it is my first one so we are taking it slow and making sure it is right,we have upgraded the cooling and fitted a an external cooler,finding the fittings has proved trying.
We have rebuilt the box as the clutches struggled as a 2,5 has gone in this one,it wasnt as expensive as I thought as well(580) that was to replace all the clutches.
I have also bought a dud second hand box to play with the governor and get it changing gear later.
The inital experience was good,I have made a hybrid throttle cable utilising one of rjes's one with and a scooby one.this allows the kick down to be used,although to be honest with 175 bhp you realy dont need it.
With an auto the only option is to use an adaptor plate,I use ds tunings one although kenedy do one to,but the rest of the parts are rjes.
I will update as it goes on,but your are welcome to come down for a ride in it when it is done,although there will only be a small window as the customer will want it back asap
I'm assuming that is a scooby conversion ? I'm also running a T25 1.9 auto, as a DG it is guttless, and I'm getting tired of being in the front of a long queue, and struggling to over take a tractor, so I'm looking for more power combined with better fuel economy, what engine would you recommend, petrol or diesel ??????
woodguru is offline   Reply With Quote
Old 05-10-2014, 04:59 PM   #54
Janine00
Chat Virgin
I have a T25 1.9 DG Caravelle 78PS, Petrol engine, 1985 reg on a B plate (Watercooled). The engine still seems quite good at present, but I may need to have a fair amount of work done in the not too distant future, as the original water pipes are very corroded at the back end, and gearbox is a bit dicky and occasionally jumps out of first. Also, we had to get a guy we know to weld the engine around where the manifold hits the exhaust as the last person that had it tried to do the exhaust himself and ended up shearing off the bolts in two places and breaking off part of the housing. (It's still holding well, so hopefully will do for a while)! However it cruises well at 60 for miles and miles, and still goes fairly easily up to 75+ on good roads (but I don't hold it at that for long). It still pulls away well, and generally only struggles a little uphill, unless they are very steep and very long (some area's of Wales and Peak District etc).
My question(s) then would be :
As I am getting a return of about 23 mpg at present, would it be worth getting a modern engine to put in it when things start to go wrong?
What sort of mpg do folks generally get when they have put newer engines in?
And approx. what cost am I looking at - all in? In an earlier post it said about 4k so I am wondering if it would be worth it in the longer term. We are in our 50's and intend to keep this for a good while to enjoy our adventure before dementia!
btw - its the original engine and it only has 43K miles on clock. MOT history supports this also, so is it likely to be correct?
Any idea's and thoughts I would be grateful.... cheers... J
Janine00 is offline   Reply With Quote
Old 02-06-2016, 06:03 AM   #55
Drew64
Drew64's Avatar
Which engine conversion would best suit the type 25 automatic gearbox.How much work would be needed to fit a Audi 5 pot?
Drew
The creator of the Evil Herbie (ex Turbothomas, now owned by SuperBee).
1991 T25 Vanagon & Seat Arosa 1.0 S
Drew64 is offline   Reply With Quote
Rate This Thread:
