Engine misfire and cut out when trying to rev the engine? - VW Forum - VZi, Europe's largest VW, community and sales
Old 16-05-2020, 06:59 AM   #1
martin.2010
martin.2010's Avatar
Default misfire and cut out when trying to rev the engine?
Hello
I'm having issues with my 71 1200 bug.
It start a small misfire at idle a week ago. I had just changed the fuel pump (because old was leaking ) change the oil and now I have big misfire, unable to get the engine to idle and would cut out when trying to rev the engine.
I have so far:
Recheck fuel pump, valve clearances and timing
Check the compression 120 to 110 psi
Cleaned and regaped the spark plugs also different coil and condenser, I checked the points too
I strip, cleaned and add new diaphragms to the carb and double check accelerator pump working
Still the same the problem
I thinking of trying new HT leads, spark plugs and points also
Sorry for long thread but I am running out ideas
Thanks
Martin
Kentish V Dub Klub
http://www.kvwk.co.uk/
HOT1200s
https://www.volkszone.com/VZi/showthread.php?t=407485
Originally Posted by paulatxntric View Post
...speed don't kill.....hitting things at speed kills and thats usually because people are driving like twats.....unfortunatly "twat cams" don't exist!
martin.2010 is offline   Reply With Quote
Old 16-05-2020, 03:10 PM   #2
Mr.Whippy
Mr.Whippy's Avatar
Trading feedback: (3)
Have you set the ignition timing since the points change ?
When you re-checked the valve clearances, did any of them need a lot of adjustment (more than 1 turn of the screw ?)
Pull all four plugs and compare colours, see if they indicate too rich, too lean or a problem with one or two cylinders in particular.
Remember, just because a part is new does not mean it is not faulty. Consider re-fitting old parts to help locate fault if required. Bosch made in india plugs have had a bit of a bad rep...
Mk 2 Scirocco 1600 GT new clutch kit
Mk 4 Golf front brake discs & pads new in box (288 mm)
- Collect for free - I need the space - PM me.
Mr.Whippy is online now   Reply With Quote
Old 23-05-2020, 12:44 AM   #3
martin.2010
Thank for your reply
It was the plugs, these one are Bosch made in Russia.
Thanks
Martin
Kentish V Dub Klub
HOT1200s
Old 23-05-2020, 05:56 PM   #4
Mr.Whippy
Mr.Whippy's Avatar
Result !
Thanks for letting us know the fix.
Old 25-05-2020, 11:45 AM   #5
Big Al
Big Al's Avatar
Really wow. Sounded like points.
Big Al is offline   Reply With Quote
Old 25-05-2020, 11:45 AM   #6
Big Al
Big Al's Avatar
Really??
