74 Devon Baywindow resto! - Page 4 - VW Forum - VZi, Europe's largest VW, community and sales
Old 20-02-2020, 10:26 PM   #31
Blasting Die Past
Blasting Die Past's Avatar
Bending up some tube.
The standard front red 9 cross brace has been binned and we are making a new one from the CDS tube, this also means we can ditch the silly amount of washers that the red9 needs to fit.
ID:	273147   Click image for larger version
Blasting Die Past is offline   Reply With Quote
Old 21-02-2020, 11:21 AM   #32
Nice work. Looks very tidy under there. I always wondered why the red9 kit required 1/2 a dozen washers on each side.
1970 1300 resto here
1970 1300 part 2
1988 Caravelle CL
Old 21-02-2020, 07:54 PM   #33
Blasting Die Past
I think they build it on a universal over size jig so itíll fit both split and bay etc, itís not great, not built very well and very over priced.
The welding is poor and not finished off nice either, this one has never seen the road and the rubbers on the steering rack have failed/split already.
Wonít be ordering any more
Old 26-02-2020, 10:03 AM   #34
Blasting Die Past
February is a busy busy month!
Chassis cage almost finished off, main rear mounting points, rose joints, and extra supports to tig weld in.
ID:	273251   Click image for larger version
ID:	273253   Click image for larger version
Old 24-03-2020, 08:47 PM   #35
Blasting Die Past
Moving onto the engine/gearbox cradle, first up we need to raise the setup as with the notches and air ride the gearbox is too low!
ID:	274121   Click image for larger version
ID:	274123   Click image for larger version
ID:	274125   Click image for larger version
