Anyone good with a lathe? - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Community > Jobs For The Boys (& Girls)
Jobs For The Boys (& Girls) Positions Vacant and Jobs Wanted. If you have an opening, post your job ad here. If you have lost your job or on the look out for a new job, place your CV or wanted ad here. Also, if you need a freelancer, contractor or want to commission some work, this is the place. NO TOUTING, USE YELLOW PAGES. Forum available for sponsorship
Old 27-12-2017, 09:12 PM   #1
redhouse53
redhouse53's Avatar
Default Anyone good with a lathe?
I'm after some simple weld-in threaded plugs (to bolt a beach buggy tub down) and was wondering if anyone on here could do it for me?
I've done a highly technical drawing, but basicly I need top hat shaped plugs to weld into 30mm box section, with an M8 threaded blind hole in them, as per the picture below (hope it makes sense)
I would need 16 of them and of course will pay
thanks
current projects
'86 Mexican, RHD Conversion
Mini Van, nearing completion
V8 Oval, starting sonn....
MantaRay Buggy, also starting soon.....
redhouse53 is offline   Reply With Quote
Old 28-12-2017, 04:27 PM   #2
Manxdavid
Manxdavid's Avatar
Trading feedback: (4)
Have you looked at M8 Rivnuts on eBay? Similar but not blind.
David Jones, Anglesey, North Wales, UK.
"Wise men talk because they have something to say, fools because they have to say something." (Plato)
Manxdavid is offline   Reply With Quote
Old 28-12-2017, 05:20 PM   #3
redhouse53
redhouse53's Avatar
I used the aluminium ones a lot on the Mini but they woudn't be up to the job, how strong and easy to use are the steel ones?
I may have another plan now
current projects
Old 28-12-2017, 10:09 PM   #4
hannahman58
hannahman58's Avatar
You'd probably need to run a tap down them once welded
hannahman58 is offline   Reply With Quote
Old 29-12-2017, 09:24 AM   #5
Stu_b
Stu_b's Avatar
Check these out:
https://rover.ebay.com/rover/0/0/0?m...2F263105730877
Stu_b is offline   Reply With Quote
Old 29-12-2017, 10:53 AM   #6
redhouse53
redhouse53's Avatar
Originally Posted by Stu_b View Post
brilliant, thats exactly what I was thinkig!!
My plans have changed slightly though, I'm now thinking of getting flat plates laser cut to the floorpan edge profile with bolt holes, then tap the holes to suit. I can then weld these directly to the floorpan. I know the place I've used before can do 15mm plate, I reckon that would be plenty strong enough,
thoughts?
current projects
Old 29-12-2017, 11:00 AM   #7
Hoosier
Hoosier's Avatar
15 mm plate?
Are you going mine sweeping with it?
Hoosier is offline   Reply With Quote
Old 29-12-2017, 11:08 AM   #8
redhouse53
redhouse53's Avatar
Originally Posted by Hoosier View Post
15 mm plate?
just thinking I need plenty of depth if I'm tapping a thread into it
current projects
Old 29-12-2017, 12:54 PM   #9
Stu_b
Stu_b's Avatar
Iíve had stuff laser cut in 15mm and itís super thick and heavy. Get most stuff, like skidplates, bag mounts etc done in 6mm and that seems over engineered for most applications.
Old 04-01-2018, 12:24 PM   #10
jpgreenwood
jpgreenwood's Avatar
Trading feedback: (8)
Am I missing something? OD of the head, OD of the plug shaft?
Also, in your drawing, it looks like the plug will sit on the inside face of the box section? If this is the case, wouldn't the plug length need to be 27.5mm considering the thickness of the metal and 25mm ID?
I work at a machining training centre and although not a turner myself, have all the equipment and trainers/students at hand who could probably do this.
Themakersnamesonthebaseofthemakersbaseplatemate
jpgreenwood is offline   Reply With Quote
