Paint Is this the right paint? - VW Forum - VZi, Europe's largest VW, community and sales
Old 15-09-2020, 04:21 PM   #1
jonnyfive
jonnyfive's Avatar
Default Is this the right paint?
Iím about to paint some repair work Iíve done on my beetle (a-post, inner arch, heater channel) and this is what the paint shop sold me - colour matched paint, 2k primer and high build. Have just spoken to them again and the guy says the paint is cellulose and assures me the 2k primers are compatible, wont react with whatís already on the car and I donít need an air fed mask - does that sound right?
https://www.dropbox.com/s/u5684ohwt6...-6602.jpg?dl=0
jonnyfive is online now   Reply With Quote
Old 16-09-2020, 01:25 PM   #2
gojira
gojira's Avatar
seems a bit odd to have sold you a mix. i'd either use cellulose primer and cellulose topcoat, or 2k primer and 2k topcoat. (although personally i'd only ever want 2k topcoat on a car)
having googled those paints it does look like they'll probably work OK together.
as to using an air fed mask - yes you are supposed to use one for any isocyanate 2k paint, but many people do occasional painting with 2k in well ventilated areas with an appropriate A2 rated respirator. i use this one: https://www.screwfix.com/p/3m-7523-h...um-a2-p3/13251
the power of the riff compels me
Dubtopia VW Club
gojira is offline   Reply With Quote
Old 16-09-2020, 01:41 PM   #3
jonnyfive
jonnyfive's Avatar
I already have a can of Upol 8 etch primer, maybe I should use that and get some Upol 5 high build from Halfords?
Sent from my iPhone using Tapatalk
Old 17-09-2020, 10:00 AM   #4
psimitar
psimitar's Avatar
Try and find the tech data sheet (TDS) for what you've been sold. TDS should say which paints it won't work with. If not then contact the manufacturer direct. Paint suppliers are normally pretty good with knowing the products they sell but many don't come from a bodywork background so rely on what the manufacturers salesman tells them.
madness is in the eye of the beholder
My '59 Beetle Resto Part I
My '59 Beetle Resto Part II
56 Oval Resto
psimitar is offline   Reply With Quote
Old 17-09-2020, 11:00 AM   #5
jonnyfive
jonnyfive's Avatar
TBH the whole 2K thing is making me feel uneasy, Iíd be much happier going down the Upol 8 & 5 route if itís going to get the job done.
Old 18-09-2020, 01:17 PM   #6
psimitar
psimitar's Avatar
So long as you can get the repair down to metal, any rust treating done, primed and topcoated in a day then you're all good
56 Oval Resto
Old 18-09-2020, 02:18 PM   #7
jonnyfive
jonnyfive's Avatar
Thanks! Will have to negotiate a child free day with the boss
Old Yesterday, 10:47 PM   #8
jonnyfive
jonnyfive's Avatar
Have swapped the 2k primer for 1k epoxy, feel happier about that - hopefully I can get decent results!
Old Today, 01:54 PM   #9
psimitar
psimitar's Avatar
So long as there's no possibility of reaction between the paints then it'll be fine. Read the TDS for each paint. I would say unless specifically stated that the 1K epoxy will need a fair few hours to fully cure before it can be topcoated but all required info should be in the TDS.
56 Oval Resto
Old Today, 08:44 PM   #10
jonnyfive
jonnyfive's Avatar
Thereís a bit of filler work to be down after the epoxy so wonít be too coating for a while.
