Another Volksrod - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Old 16-06-2017, 11:34 AM   #21
vialli
vialli's Avatar
Most of the Limebug kit went together ok. I did have some issues with their lower Airbag bracket though on both sides. In order to get everything to fit I had to open up the holes where shock gets attached for the bolt to slide through. Not sure if I was unlucky or the problem was with the chassis casting or the Limebug bracket.
Anyone else fitted one of these kits with any issues?
ID:	196769   Click image for larger version
vialli is offline   Reply With Quote
Old 16-06-2017, 11:43 AM   #22
vialli
vialli's Avatar
Front end together. Only issue here was that the lower through rod is too long to retain the blanking disc in the end of the trailing arm. I did ring Limebug & they said this does occur in some instances. Looks to me that it would always happen. I'll have to sort some other way of sealing this up at some stage, anyone else had to fix this?
ID:	196785   Click image for larger version
Old 16-06-2017, 11:59 AM   #23
Stu_b
Stu_b's Avatar
I wondered if this would be an issue. The lower shock mount is at an angle and their bracket looks to be vertical.
I make skidplates and stuff...
Stu_b is offline   Reply With Quote
Old 16-06-2017, 12:00 PM   #24
vialli
vialli's Avatar
So at this stage I'd got the chassis to a point where I was happy with it. All new brake lines fitted. Fuel line replaced, this took a while but seems I was lucky compared to others that had gone through trying to replace theirs. I'd coated the underside with underseal as well.
Next step was to look at the body for the roof chop
Old 16-06-2017, 12:06 PM   #25
vialli
vialli's Avatar
You're right. As Limebug engineered this as a bolt on kit you'd have thought the bracket would be contoured more so that it aligns better. I was worried the chassis castings were out of true at first. It's not cheap their stuff as well.
Old 16-06-2017, 02:11 PM   #26
Coo
Coo's Avatar
Great progress !
"Veni, Vidi, Velcro" - I came, I saw, I stuck around
Coo is offline   Reply With Quote
Old 16-06-2017, 11:42 PM   #27
vialli
vialli's Avatar
Originally Posted by Coo View Post
Great progress !
Thanks, it's taken a while though. What I'm showing now is what I've done in the past. I bought the car nearly 2 years ago but didn't at the time decide to post progress on a day to day basis ( I knew It'd be a long & slow journey). Now as I'm getting nearer the finish line I thought I'd be brave & show people what I've done.
Old 17-06-2017, 09:25 AM   #28
moler
moler's Avatar
Trading feedback: (7)
Looking forward to progress
Are the front air shocks upside down?
Moler Inc, Volksrod pick-up build, 2700+ pics and counting
1971 Dormobile Minibus, twin slider
Sydney - 1972 Australian Squareback
moler is offline   Reply With Quote
Old 17-06-2017, 11:02 AM   #29
vialli
vialli's Avatar
They can only be assembled one way, they come with an 'eyelet' at the base to attach to the trailing arm & a threaded spigot to go through the tower.
You did cause a pause for thought though!!!!!!!!!
Old 17-06-2017, 09:34 PM   #30
moler
moler's Avatar
Doh! of course they can only go one way, I'm not blond honest
I went and checked mine, and mine mount what I would consider as the right way, how odd?
