About time i showed you my '70 1300. - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Closed Thread Post New Thread
Old 25-02-2008, 12:55 PM   #21
beetlecharles
I really must get out more
beetlecharles's Avatar
Trading feedback: (5)
It does looks suspect but theres only one way to find out!
Have you thought about a genuine complete quarter panel, although they are pretty pricey?
Cars.
beetlecharles is offline
Old 25-02-2008, 12:58 PM   #22
chrisaircooled
chrisaircooled's Avatar
looks good made keep it up dated
Life is simple until you wake up!
chrisaircooled is offline
Old 25-02-2008, 07:43 PM   #23
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Thought about it but too pricey for me at the moment.
Gonna have to do with Klokkenholm panels and homemade pieces.
Gotta get my bay welded for its MOT before i get on with the bug.
Not much to do (a few little patches) so it shouldn't take too long. Fingers crossed.
1970 1300 resto here
1970 1300 part 2
1988 Caravelle CL
Zebedee is offline
Old 26-02-2008, 02:13 PM   #24
Zebedee
Zebedee's Avatar
I've had a poke around the tacked on bits on the arch and it seems pretty solid there.
It looks like the rot spread too far up the arch for the suspension mount repair panel to cover so they welded a plate on.
Still gonna cut the patches off and have a proper go at making it look a bit nicer.
It looks a bit like a patchwork quilt under the arch but i think a bit of grinding and some stonechip should have that looking OK.
1970 1300 part 2
1988 Caravelle CL
Zebedee is offline
Old 26-02-2008, 07:58 PM   #25
satelliteone
satelliteone's Avatar
Brave guy, Your not alone. keep em pix flowing. I know the motivation sags a little..but the outcome will glorious im sure.
Love the sunroof..might try and retro fit one in my bug.. top job so far!
Mk1 Golf Gti
satelliteone is offline
Old 26-02-2008, 08:41 PM   #26
Zebedee
Zebedee's Avatar
Been watching your thread with interest. Nice work you've done there.
The sunroof is only a tilt model that I won in a competition in vw motoring in '98 and its been great for the summer. Glass lifts out completely too.
Only probs is 10 years later it doesn't close tightly at the rear and water gets in when it rains.
Can't figure out how to sort it either.
Was thinking of removing it completely and welding the hole up as i was planning on doing some historic rallying with it and it won't pass scrutineering because of the glass sunroof.
Too much work to do a good job on such a visible area so i might just buy a cheap hillman imp and use that instead.
1970 1300 part 2
1988 Caravelle CL
Zebedee is offline
Old 27-02-2008, 02:34 PM   #27
satelliteone
Maybe the seals have sagged over time zeb. im sure a little buff up with very very light sand paper, then add/rub black shoe polish, then clean off might make then seal proper. Other than that if there is a way to adjust the gap, try that. or replace the seal totally.
thanks for the compliment on cabbage. Waiting for the weather to turn out warm , before i get out and spray the rest of the car. Till then im building another engine for cabbage. also been pondering on hydrogen injection for the new motor.. experimental..
good luck tho.. keep up the good work
Mk1 Golf Gti
Old 27-02-2008, 07:46 PM   #28
Zebedee
Zebedee's Avatar
I think the problem is the sunroof has been shut for so long its compressed the seal.
There doesn't appear to be any way to adjust the latch so i'm gonna remove the catch from its mount completley and see if i can shim it somehow.
You've got a long time to wait if you're waiting for the warm weather. Its usually the mid week of july isn't it?
What size engine are you building for cabbage?
I've got the stock 1300sp for mine in bits at the mo. Gonna fit a minnow fish carb, 1.25:1 rockers and a set of taper tips for a bit of retro power.
1970 1300 part 2
1988 Caravelle CL
Zebedee is offline
Old 27-02-2008, 08:41 PM   #29
satelliteone
im going to build a 1600 DP. Ive got the as41 case , and a few bits n peices. Waiting to get another engine as a donar. Just cleaning all the bits i have already..
Saving for some new parts too..dam exspensive this bug building lark. Engine and body work. ive could of bought a decent car by now..lol.
Cabbage has a working engine, but has a bad knock on the bottom end, needs a newly built motor..
Mk1 Golf Gti
Old 28-02-2008, 12:34 PM   #30
Zebedee
Zebedee's Avatar
Woah, sparkly crank case.
Woke up this morning to the first lovely and dry, no wind day in weeks and i've got a bloody case of manflu.
Sitting here at the moment wrapped in a thick blanket shivering.
Was hoping to get something done outside but i can't even stand without my legs shaking.
1970 1300 part 2
1988 Caravelle CL
Zebedee is offline
Tags
1300, beetle, rally, resto
