Red light on clock - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Tech Forums > Business Recommendations
Business Recommendations Please use this forum to recommend garages, workshops or indeed any businesses that provide good service. Help other members find the 'good guys' (and maybe avoid the cowboys.) Please only recommend companies where you have personally had work done. Any blatant 'plugs' for your own business will be deleted. Become a Member Sponsor here. Please read the sticky threads BEFORE posting - it may save you time in the long run.Forum available for sponsorship
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 29-08-2011, 09:45 PM   #1
64rag
Chat Virgin
64rag's Avatar
Smile Red light on clock
My 6v beetle is showing a Red light on the clock when running on idle speed, if i blip the acc the light goes out but comes back slightly
dimmer & when the car is running the light stays out. Is this the dynamo not charging regulator or both?
please help!
thanks!
64rag is offline   Reply With Quote
Old 31-08-2011, 05:56 PM   #2
Peaches-and-Noel
Peaches-and-Noel's Avatar
I'd say that as long as the light goes out, everything's fine
Maybe I'm idle (well, yes, I am), but the fact that it goes out suggests that everything's working broadly ok, so I'd be tempted to leave it alone if it were mine.
Or #1:- Is the idle speed "about right"? If it's too low you could just turn it up a bit. You could check the tension on the generator belt, then look at the brushes in the generator (not bushes), the earth strap from the battery and the condition of the wiring between the generator and the battery itself. You would imagine that the regulator is regulating, from what you describe, so you could just gently polish the contacts on that a bit.
Or #2:- It is an awful, and dangerous, car that will soon catch fire and emit marble sized fireballs of death. Therefore, I will do the decent thing and buy it off you for three pounds, seven and sixpence.
3 is the magic number
Peaches-and-Noel is offline   Reply With Quote
Old 27-09-2011, 07:22 PM   #3
dazarooney
Chat Virgin
please help!
thanks!
Did you get to the bottom of this problem?
http://www.ecoledlight.co.uk/
dazarooney is offline   Reply With Quote
Rate This Thread:
