For Sale SWB Drag Buggy - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Volkszone Classifieds > Vehicles For Sale
Vehicles For Sale If you have a Vehicle for Sale or are looking for something - Take a Browse Around. Private sales only please. Commercial and 'regular' sellers, please take a banner advert or become a Member Sponsor and support the site before running your 'business' or 'just selling' through VZi. VZi Classifieds were originally set up as a 'free to use' facility for the members who contribute with threads and replies in the Mech Tech, Chat and Readers Rides forums etc. As VZi has got bigger, we see more and more new Members who ONLY ever post in the Classifieds and contribute nothing (neither monetary nor in content) to the forums. This is fine, however to use our facility this way you will need to become a Member Sponsor.
Old 10-09-2019, 10:54 PM   #1
DaveB9
Default SWB Drag Buggy
I've been toying with selling this for a while (and had a half-hearted go before), but as multiple family illness has prevented me using it at all this year, I think it has to go.
The UK’s quickest SWB buggy: mid 13s on a mild 1776 and well into the 11s on its current 2110. Alternatively, large parts of it could be used to build a fast street buggy (it has no V5).
Chassis: Semi-spaceframe with 3mm wall box section cross braced base, new framehead, Ron Lummus Racing 2” solid raised gearbox mounts (low without negative camber), custom made chromed jointed steering column with quick-release wheel. CDS tubing roll cage bent by Chris Isaacs Racecars, tagged to MSA 10.50 seconds spec. Chassis stove enamelled in dark blue metalflake.
Suspension and brakes: Mint German front beam with adjusters, two sets of castor shims, dropped spindles, discs, brake bias valve, stainless braided lines. At the rear there are Sway Away 28mm torsion bars, Sway Away adjustable spring plates, built up flop stops, Cotsweld wheelie bars, all detailed in stove enamelling, Koni red shocks.
Interior: Bead-rolled and powder coated ali Dzus-mounted floor and panelling powder coated pearlescent white, made by Chris Isaacs Racecars. Hinged panel for fuelling and small matching dash panel. Kirkey ali seat with cover, window net, CNC staging brake with launch control, Berg 60% shifter, Autometer Monster Tach, oil pressure and temp gauges in chrome cups. Five point Sabelt harness with shoulder pads.
Body: GP Mark 1, bonnet now a lightweight GT one. Front wings modified to sit higher, allowing the car to sit extremely low. Body attached by Dzus fasteners. Restored and painted in Fiat Surf Azure. Signwritten by Pro Sign in gold leaf.
Wheels and tyres: polished genuine Centerlines, 3.5 inch fronts with new 135 Contis, 8.5 inch rears with M&H 275/60 DOT Racemaster drag radials (4 race meetings on them).
Gearbox: Type 1 race box built by Cogbox. Modified superbeetle mainshaft, chromoly shift forks, close ratio 3rd and 4th with welded hubs, superdiff, heavy duty side plate, Sway Away race axles in pre-62 short tubes.
Engine: 2110 built by Paul Miller. Chromoly counterweighted crank, lightened flywheel, H beam rods, Mahle forged barrels and pistons, MoFoCO heads 42X37.5mm valves, Berg oil pump and cover, straight cut cam gears. Garrett T3 turbo, Turbosmart blow off valve, Tial wastegate, chargecooler with ice tank and pump, VW Speedshop EFI with 42mm throttle bodies and Omex 600 ECU. Bosch 044 pump, Facet lift pump, swirl pot, Turbosmart pressure regulator, all braided lines and anodised fittings for fuel, oil and CSP breather, Mocal oil cooler.
Only 7 passes on motor since rebuild with new heads, rings and bearings. This is a well sorted, properly dialled in car with the event wins to prove it.
£10.5k complete, negotiable without engine and fuel system. That represents less than a quarter of what it has cost me to build.
PM me if interested but please note the reason for sale - please only contact me if serious.
(The pictures below pre-date the current engine and rear wheels, will try to find an up to date picture)
Name:	Plan B for sale 2.jpg
ID:	267437   Click image for larger version
ID:	267439   Click image for larger version
ID:	267441   Click image for larger version
Name:	Midi National finals by JHunt.jpg
DaveB9 is offline   Reply With Quote
Old 10-09-2019, 11:05 PM   #2
DaveB9
Here's one of the new engine set up and the new Centerlines / M&H Racemasters on the back. Since this was taken an alternator has been fitted.
Old 12-11-2019, 08:10 AM   #3
ljs
ljs's Avatar
Wondered if this is still for sale.
Have pmed you..
Cheers.
ljs is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
