Brake Pedal Vibration after a routine tire change - VW Forum - VZi, Europe's largest VW, community and sales
Old 27-10-2014, 07:20 PM   #1
58bug_1
Chat Virgin
58bug_1's Avatar
Default Brake Pedal Vibration after a routine tire change
1958 beetle delux 1200 6v (standard 165/80/15)
I recently had a new set of tires fitted and found my brake pedal vibrating (pumping in and out)
The vibration increases and decreases with speed. No other vibration or noise during driving. Only on the brake pedal when breaking.
The breaks were spoton before the tire change. I've asked a aircooled specialist in London who simply wants to change the breakdrums and master cylinder which seems completely dramatic.
Any idea why a simply tire change can cause this?
Thanks alot
58bug_1 is offline   Reply With Quote
Old 27-10-2014, 07:28 PM   #2
Manxdavid
I really must get out more
Manxdavid's Avatar
Trading feedback: (4)
It sounds like the tyre fitter's been a bit ham fisted tightening the wheel bolts and has not tightened them evenly warping a drum. Wide 5 drums can be quite easy to distort and the bolts should be tightened gently and bit by bit.
You may be looking at replacing drums and shoes (to match the new drums), no idea why he'd want to replace the m/cyl though.
David Jones, Anglesey, North Wales, UK.
"Wise men talk because they have something to say, fools because they have to say something." (Plato)
Manxdavid is offline   Reply With Quote
Old 27-10-2014, 09:52 PM   #3
Happystamps
Happystamps's Avatar
Trading feedback: (5)
Probably a silly question.... You've made sure the bolts are tightened properly?
My Early Bay resto thread
Plans for bits to make yourself:
Rock and roll style bed
Early bay gearbox mount
Early bay passenger seat brackets
Hoover bit
EB tailgate post
EB engine lid stay rollers
https://www.dropbox.com/sh/dblsij1wl...q618iuoha?dl=0
Happystamps is offline   Reply With Quote
Old 28-10-2014, 01:16 AM   #4
ndk_1302
ndk_1302's Avatar
Whs. ^^^
Drums will need changing
ndk_1302 is offline   Reply With Quote
Old 28-10-2014, 02:17 AM   #5
VWCOOL
loosen all your wheel nuts and re-torque
VWCOOL is offline   Reply With Quote
Old 28-10-2014, 05:08 PM   #6
baggabones
Registered User
A Tyre fitter being ham fisted when fitting wheel bolts??? Never! :
baggabones is offline   Reply With Quote
Old 28-10-2014, 10:20 PM   #7
Bada Ben
Bada Ben's Avatar
5 bolt Beetle drums are not as rigid as you may think. Warped roadwheels will easily distort a drum when tightened, but the warp isn't permanent. Before spending money on new drums or having them skimmed, try to identify which one is vibrating, and change the wheel. Or change each one in turn, until the vibration goes, then get the offending wheel checked. The equipment in modern tyre bays often can't accomodate the VW 5 bolt wheels, so the fitters "improvise", and this can cause damage.
Nothing is foolproof to a sufficiently talented fool
Bada Ben is offline   Reply With Quote
Old 29-10-2014, 12:50 AM   #8
Kryten
Kryten's Avatar
Even torque is as important as tightness; I use a torque wrench on my wheel bolts. I would never rely on a tyre place to do it properly, they usually rattle them on at ridiculous torque.
Kryten is offline   Reply With Quote
Old 29-10-2014, 01:41 PM   #9
58bug_1
Chat Virgin
58bug_1's Avatar
I checked the bolts and they all seems reasonably hand torqued so were certainly not too tight. I loosened the nuts and re-tightened them evenly and the issue persisted.
Although, it felt slightly intermittent at low speed and stronger at a higher.
I didnt jack the car up so wondering if having the wheels off the ground and perhaps putting them on and off would make any difference . I will also try swap them with my spare and see if the issue is with the wheel.
Old 29-10-2014, 01:50 PM   #10
evilC
evilC's Avatar
And over stress the bolts/studs in the process. Having had a stud fail that eventually caused the whole wheel to shear off with potentially fatal consequences (the wheel hit the top of a flyover parapet before bouncing back!! A 30ft drop onto the Coventry inner ringroad would have killed someone) all the engineers that looked at the studs were convinced over tightening was the problem. My Merc's extended M12 bolts were rattled on with a gun so tight that the bolts could be seen twisting with the torque to undo them. Our Octavia went in for a service and came back with the rear bolts torqued up to 230 - 250ftlbs when they should have been 85ftlbs i.e. 3x the required torque! I insisted on new bolts including a full set of security bolts.
Have you noticed that Ed, the lanky moron in Wheeler Dealers always puts wheels on with a rattle gun, when he makes a BIG play about using a torque wrench elsewhere? For me he lost all credibility when I saw him put the first wheel on.
evilC is offline   Reply With Quote
Rate This Thread:
