If you're gonna make a special, make it special - Page 12 - VW Forum - VZi, Europe's largest VW, community and sales
Old 20-12-2017, 12:44 PM   #111
G-Dawg
G-Dawg's Avatar
Going to follow this thread, looks fantastic so far, great skills! [I like the classic jags and Ferrari's in the background too!
Ps the horn push just pops off with a bit of gentle force.
G-Dawg is offline   Reply With Quote
Old 20-12-2017, 10:13 PM   #112
al_kaholik
al_kaholik's Avatar
Trading feedback: (23)
I seem to remember it pops off in each corner then needs rotating 90 degrees to pull out of the middle of the wheel, but at that point it'll not be attached.
Wasserboxer conversion
'77 Jap import FI and Aircon
al_kaholik is offline   Reply With Quote
Old 21-12-2017, 08:48 AM   #113
dc66
dc66's Avatar
Thanks. I'll give it a try
dc66 is online now   Reply With Quote
Old 21-12-2017, 02:12 PM   #114
dc66
dc66's Avatar
With the fuel tank frame tacked in place and the tank in, it's obvious that it will be too tall.
I have a few options:
Cut down the tank
Separate the top and bottom of the tank and make a new,slimmer top
Make a whole new tank
Make a tank to fit above the gearbox.
I plan to do some long distance touring in the car so a smaller, cut down tank doesn't really seem the right way. Moving the tank behind the seats will exaggerate the weight imbalance. Hmmmm I think I'll put off the decision till Later in the build!
ID:	223474   Click image for larger version
Old 21-12-2017, 02:14 PM   #115
dc66
dc66's Avatar
A twin tank system? ...........slimline one up front and an auxiliary one behind the seats. ...... that could work
Old 21-12-2017, 04:27 PM   #116
GlenAnderson
Saddest VZi'er 2020
GlenAnderson's Avatar
VZi Member Sponsor
Trading feedback: (18)
Or reprofile the underside to drop it further down?
My worst worry about dying is my wife selling my stuff for what I told her it cost...
GlenAnderson is online now   Reply With Quote
Old 19-01-2018, 11:45 PM   #117
dc66
dc66's Avatar
I've been busy recently so not as much progress as I'd like.
That hasn't stopped me thinking about this though. I've actually been loosing sleep over it! Lol
It's the dash that's been causing me the grief. It's amazed me how much thought has to go into this area. It affects the scuttle, front bodywork, door design, gauge choice, steering action, wheel position as well as dictating the side bodywork. If I get it wrong it'll cause major problems or compromises later on.
The hoop that I welded in as the lower dash edge was too high so I cut and welded it 20mm lower. That doesn't sound much but it allowed me to drop the fuel tank down, solving one issue! I'm confident that the tie rods won't hit the tank as it's been "clearenced" lol
When I have finished this car one of the last jobs will be to fit the gauges. However I needed to make the choice over which gauges to use now, so I can design the dash around them. My choice is between the original 1966 and the more modern (and sporty) 1303 gauge.
I plan to have a speedometer, rev counter, fuel gauge and water temp gauge. I also need a rear fog light switch and warning lamp as well as the brake warning lamp.
Old 19-01-2018, 11:48 PM   #118
dc66
dc66's Avatar
After a lot of research I've gone for the original 1966 gauge. I can get a matching rev counter from several places. The water temp gauge and fuel gauge is a little more problematic, but I do have a cunning plan......
Old 19-01-2018, 11:52 PM   #119
dc66
dc66's Avatar
Now I've done the dash design I could get on and build it.
Using the 30mm tube I bent up the top hoop. This was really tricky to get right! I ended up making it from 4 pieces. It's a little hard to capture in a photo, but it has a dome for the gauge pod and curves in two axis into the A post area. I didn't want it to just go straight across the car.
Old 19-01-2018, 11:55 PM   #120
dc66
dc66's Avatar
I've photographed it the best I can
ID:	227282   Click image for larger version
