About time i showed you my '70 1300. - Page 301 - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-12-2019, 06:50 PM   #3001
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Managed to blow compressed air through the accelerator pump fuel discharge nozzle so refitted it. Blew through the rest of the jets while the carb was apart too just to make sure. Reassembled and it now revs properly.
Set of trim removal tools arrived in the post today so i could pop off the passengers door panel without resorting to using a screwdriver and possibly scratching the paint. Only 3.22 off ebay too.
Fitted the bonnet handle and was quite pleased that the bonnet still opened OK.
ID:	271557   Click image for larger version
1970 1300 resto here
1988 Caravelle CL
Old 07-12-2019, 06:55 PM   #3002
Zebedee
Zebedee's Avatar
All ready for its MOT on wednesday so took one last picture in the garage. I kinda miss the old bonnet stripes.
1988 Caravelle CL
Old 09-12-2019, 06:45 PM   #3003
Zebedee
Zebedee's Avatar
Welded a bar onto the mirror mounting nut to stop it turning as its tightened up as there wasn't a captive nut in the door.
Forgot how pointless beetle mirrors are compared to a modern car (or even a T3) as you can barely see anything. Should be fun reversing out the garage and up the drive.
Stuck the vapour barrier back on.
ID:	271611   Click image for larger version
ID:	271613   Click image for larger version
1988 Caravelle CL
Old 09-12-2019, 06:47 PM   #3004
Zebedee
Zebedee's Avatar
Took a trip to the hospital in Workington to pick up some chrome trim to replace the final missing piece from the front 1/4. Just needs a quick polish up as it was quite tarnished so i sanded it with 2000 grit wet and dry.
1988 Caravelle CL
Old 10-12-2019, 11:53 PM   #3005
bugtastic
bugtastic's Avatar
Good luck for tomorrow
life is what you make it
bugtastic is offline   Reply With Quote
Old 11-12-2019, 11:47 AM   #3006
Zebedee
Zebedee's Avatar
Cheers.
A break in the weather allowed me to reverse it out of the garage for the first time in years and turn it round.
The ignition light has now decided it won't go out until the engine is revved to about 3000rpm but then stays out. Not sure whether its the brushes or voltage regulator? Its been fine for a couple of weeks now and decided on the morning of the test to play up.
Also, i've got the seat back as far as it'll go before the seat base hits the floor and my left knee hits the steering wheel when i lift it off the clutch. Not sure whether to knock a couple of dents in the floor so it slides further back or just fit a smaller steering wheel.
ID:	271635   Click image for larger version
ID:	271637   Click image for larger version
1988 Caravelle CL
Old 11-12-2019, 12:17 PM   #3007
vialli
vialli's Avatar
Looking good , best of luck with the test.
vialli is offline   Reply With Quote
Old 11-12-2019, 01:50 PM   #3008
keekster64
keekster64's Avatar
Ride height looks spot on, just a tad lower than stock.
Old 11-12-2019, 01:55 PM   #3009
type3
type3's Avatar
Trading feedback: (10)
Good luck with the MOT.
type3 is offline   Reply With Quote
Old 11-12-2019, 01:59 PM   #3010
skip*rat
skip*rat's Avatar
Big day at last !
Good luck with mot
Tags
1300, beetle, rally, resto
