About time i showed you my '70 1300. - Page 6 - VW Forum - VZi, Europe's largest VW, community and sales
Old 05-05-2008, 09:06 PM   #51
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Been playing with my bug jigsaw.
The replacement bulkhead panel needs a bit of work but nothing compaired to whats currently on it.
ID:	215081   Click image for larger version
1970 1300 resto here
1988 Caravelle CL
Old 05-05-2008, 09:12 PM   #52
Zebedee
Zebedee's Avatar
Looks like i might have to start looking out for a more solid floorpan.
Seems i need floorpan halves, napoleon hat section, framehead and some of the underside of the spine.
Theres a hole the size of your fist just infront of the pedal support and the master cylinder bolt near the spine has sunk into the napoleon hat.
Drivers door post is a little soft too.
ID:	267785   Click image for larger version
ID:	267787   Click image for larger version
1988 Caravelle CL
Old 06-05-2008, 01:16 PM   #53
Zebedee
Zebedee's Avatar
I'm in two minds now whether to bite the bullet as it were and continue cutting and welding or just look for a more solid shell and chassis and start from scratch.
1988 Caravelle CL
Old 06-05-2008, 02:44 PM   #54
TAXI!
TAXI!'s Avatar
didnt realise you had a thread.
1975 'TAXI' Beetle
2003 20V TURBO BEETLE
2007 1.9TDI T5
TAXI! is offline   Reply With Quote
Old 06-05-2008, 02:45 PM   #55
TAXI!
TAXI!'s Avatar
id start cutting and wleding, its really not that bad, whatever you buy unless u spend a fortune your going to have to do something somewhere along the line. so might aswell do this one, you wont have the same feeling from any other car
1975 'TAXI' Beetle
2007 1.9TDI T5
Old 06-05-2008, 08:16 PM   #56
Zebedee
Zebedee's Avatar
Must admit i have seen worse, though they are now being used to fill ditches.
This great 5 bargain a mate picked up was ever so slightly rotten.
I did end up with a nice solid rear wing off it though.
My old 1303 was rotten as a pear too.
Think i'll stick with it and get it welded up. Better the devil you know and all that.
1988 Caravelle CL
Old 13-05-2008, 12:56 PM   #57
Zebedee
Zebedee's Avatar
Not got around to doing anything photo worthy lately.
A bit of underseal scraping, wirebrushing and red leading. Boring really.
1988 Caravelle CL
Old 19-05-2008, 08:43 PM   #58
Zebedee
Zebedee's Avatar
Today i welded in some bracing for the door opening in readiness for some channel work.
Wondered what was hiding under here.
Ah, the original bulkhead.
ID:	215049   Click image for larger version
1988 Caravelle CL
Old 19-05-2008, 08:50 PM   #59
Zebedee
Zebedee's Avatar
Managed to remove the pedals and the master cylinder bolt that had sunken into the napoleon hat section and found a hole or two.
Naps hat is a little rotten.
The majority of the frame head is solid with just a couple of 50p sized holes.
It'll definately need a bottom plate and napoleon hat section though.
ID:	215065   Click image for larger version
1988 Caravelle CL
Old 19-05-2008, 09:59 PM   #60
event horizon
event horizon's Avatar
Zebedee, it'll look a million times better once you cut out the rot.
Plenty of people on here have done this area recently , me included.
Glad to see your sticking with it!!
event horizon is offline   Reply With Quote
Tags
1300, beetle, rally, resto
