About time i showed you my '70 1300. - Page 8 - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-06-2008, 08:27 PM   #71
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Spent the afternoon grinding the remains of the old bulkhead out of the car and trying to get the replacement one to fit correctly.
Not as easy a job as i thought it would be.
1970 1300 resto here
1988 Caravelle CL
Zebedee is online now   Reply With Quote
Old 10-06-2008, 09:00 PM   #72
Zebedee
Zebedee's Avatar
Today i cut the patch off the inner front arch and found another patch.
Took that one off and found the original arch.
Same on the other side, though only a small patch this time.
ID:	215153   Click image for larger version
ID:	215161   Click image for larger version
ID:	215169   Click image for larger version
1988 Caravelle CL
Old 10-06-2008, 09:02 PM   #73
Zebedee
Zebedee's Avatar
Also i cut a bit more of the front bulkhead as the rot spread further up than i first thought.
ID:	267801   Click image for larger version
ID:	267803   Click image for larger version
1988 Caravelle CL
Old 10-06-2008, 09:11 PM   #74
Zebedee
Zebedee's Avatar
Trial fitting of the replacement panel.
Still needs a little bit trimming off so they fit together properly.
ID:	215129   Click image for larger version
ID:	215137   Click image for larger version
1988 Caravelle CL
Old 10-06-2008, 09:54 PM   #75
event horizon
event horizon's Avatar
That looks better already, a solid panel is always a boost to the moral!
And it looks like your getting somewhere at last.
Keep at it Zebedee.
event horizon is offline   Reply With Quote
Old 10-06-2008, 10:03 PM   #76
vanpegg
vanpegg's Avatar
Ouch! Couple of nasty bits at the back.
Nicely caught tho.
I too like the green & stripes
Flame on...
vanpegg is offline   Reply With Quote
Old 10-06-2008, 10:06 PM   #77
vanpegg
vanpegg's Avatar
OUCH!
& the bulkhead.
Just shows there's hope for us all.
& I thought my last 6months were bad...
Kudos.
Flame on...
Old 11-06-2008, 01:08 PM   #78
Zebedee
Zebedee's Avatar
It wouldn't be that bad a job if it hadn't already been "restored" by a VW "specialist".
I've found more botched jobs than i can count on both hands.
Got myself a vented engine lid for free (to go with my free bonnet) thats gonna get sprayed satin black with a pair of white stripes. I'll leave the rest of the car green with the white stripes.
I removed all the baffles from the rusty stock exhaust box as they were loose and then welded it back up. Started it up on my engine stand and when it was revved it blew itself apart at the seams. Did sound mega rorty for a few seconds though.
Think i'll fit my spare standard exhaust and a pair of baffleless taper tips instead.
I like smilies BTW.
1988 Caravelle CL
Old 12-06-2008, 08:16 PM   #79
Zebedee
Zebedee's Avatar
Got the bulkhead welded in, ground down and seam sealed today.
Also adjusted the front wings and bonnet so they fit better.
1988 Caravelle CL
Old 15-06-2008, 12:14 PM   #80
Zebedee
Zebedee's Avatar
I'm not sure whether i should remove the door to cut out the heater channel or if i should leave it in place.
I think it might get in the way if i try with the door on.
1988 Caravelle CL
Tags
1300, beetle, rally, resto
