Rust Removal Around Windows?? - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Tech Forums > Engineering Tech
Engineering Tech A Q & A Forum devoted to Engineering Issues that don't necessarily fall into Aircooled or Watercooled Tech. Got a problem? Or an engineering question? Even a buildings or property engineering question? Then ask in here. Please, no 'For Sale' or 'Want To Buy' ads, plugs for your 'business', links to 'for sale' ads or Ebay links to your (or your mate's) auction (use the VZi 'Classifieds' section) - this also includes thinly veiled 'What's My Car Worth?' threads and "Who Can Sell Me A . . ." posts.
Old 25-11-2018, 12:29 PM   #1
reesy
Default Rust Removal Around Windows??
Hi, I have rust around the bottom of the windows under the seals. Here it has small holes.
So several questions:
When I remove the rust with wire brush and sandpaper attachments on the drill, under neath is a dark grey area, do I need to remove this back to shiny metal or is this stable? I'll attach a photo. it looks like picture of when people convert rust with phosphoric acid.
Next, there is no access inside the panal to remove rust on the inside! Any suggestions, do I just have to leave it? When filling the hole will it just fall though as I cant put anything behind it as no access, any one have any methods? I thought to put epoxy resin on and not sand flush to metal as it may fall through.
Also after this is done I need to prevent water going under the seals again. All the windows had water under the bottom part of seal, should I be putting sealant in first or just around the seal after, what is recommended? I dont want it to be too permenent as may need to remove in the future.
After sanding do I need to treat with phosphoric acid as well as maybe microscopic rust? I have some. Should I try to spray it through the holes?
Many thanks.
reesy is offline   Reply With Quote
Old 25-11-2018, 12:35 PM   #2
reesy
Oh yeah its an aircooled t25 from 1980. heres a pic of grey area under rust.
Old 30-11-2018, 08:26 PM   #3
dc66
dc66's Avatar
That needs cutting out and a new piece welding in.
dc66 is offline   Reply With Quote
Old 24-07-2019, 11:53 PM   #4
slartybartfast
slartybartfast's Avatar
Trading feedback: (3)
Just had mine done ,new metal required and don't use fairy to put seals it promotes rot.use cooking oil.
Sent from my SM-N950F using Tapatalk
"What you see when you havn't got your Gun! pair of 640/15" crossplies small rear small safari, creative polished pop out frames wtd :-)
slartybartfast is offline   Reply With Quote
Old 25-07-2019, 05:23 PM   #5
reesy
Good point on the oil!
Rate This Thread:
