Area 1200:Performance Pages - Page 82 - VW Forum - VZi, Europe's largest VW, community and sales
Old 17-12-2019, 11:12 AM   #811
HOT 1200
Some more Cam wheel detail
Anyone can make a big engine go fast!
But only a few know how to make a lil engine go faster!
1192cc 20.4 sec 1/4 mile on single solex 28 !
HOT 1200 is offline   Reply With Quote
Old 19-12-2019, 05:30 PM   #812
andy198712
andy198712's Avatar
Trading feedback: (4)
nice! have you seen the 1200 competitions they hold over the channel? can't recall where exactly.
they have an NA class and a power adder class, just meet up and do some dyno pulls ect.
i'm keen to enter one year, the turbo record is 167bhp i think.... and i'm currently stripping my 1200 at the minute to build up
andy198712 is offline   Reply With Quote
Old 20-12-2019, 02:19 AM   #813
psimitar
psimitar's Avatar
Originally Posted by HOT 1200 View Post
CARBS
TWIN Weber IDF 36 running 26mm venturi, 115 main 55 idle 215 Airs (Currently experimenting with emulsion tubes)
The Alfa F57 that came with the carbs is actually smoother than the F11, strange as F11 is normally the goto Emulsion tube for VWAC Perhaps the F57 is more suited to the small capacity engine
EXHAUST
Genuine Bugpack 1200 header and quiet pack......
Will be doing some 0-60 testing soon, will let you know the times
From my knowledge of emulsion tubes they kinda work inversely to the revs/load the engine is at.
So at low revs the holes at the top of the tube are being used and as the revs rise the fuel level drops exposing the lower holes.
Hence you can fine tune your AFR by adding or removing holes at the respective point on the tube for the revs and load. The bigger or more holes then the richer the mixture becomes. I think it's richer, could be leaner as been ages since I messed around with this.
I fine tuned my 1641 with twin ICT's and a 009 along with lighter springs in the 009.
madness is in the eye of the beholder
My '59 Beetle Resto Part I
My '59 Beetle Resto Part II
56 Oval Resto
psimitar is offline   Reply With Quote
Old 13-01-2020, 04:43 PM   #814
HOT 1200
HI Folks
Did some comparison test runs between F57 Etubes and F11 Etubes.
Whilst the F57 seem smoother, the F11 works better in my 1200 set up and much quicker/aggressive above 3500 rpm
Just over a full 1 second difference in my 0 to 50 acceleration tests.
Old 16-01-2020, 04:50 PM   #815
HOT 1200
So...more testing done on the new HOT 1200
Testing started with a 0-50mph = 12.66secs
Changed the F57 tubes out for F11's
Times improved down to 11.59secs
Minor tweaking and jet changes
Best time recorded so for
0-50MPH 11.22secs
1200 performance, hot 1200
