If you're gonna make a special, make it special - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Old 11-11-2017, 11:00 PM   #21
gary71
Sounds like a great project, watching with interest!
gary71 is online now   Reply With Quote
Old 12-11-2017, 08:14 PM   #22
Eman UP Edam
Eman UP Edam's Avatar
Watching with interest :-)
Eman UP Edam is offline   Reply With Quote
Old 13-11-2017, 10:47 AM   #23
al_kaholik
al_kaholik's Avatar
Trading feedback: (23)
I'm in too. Looking forward to seeing this progress. WBX on hold as usual for me...
Wasserboxer conversion
'77 Jap import FI and Aircon
al_kaholik is offline   Reply With Quote
Old 13-11-2017, 08:55 PM   #24
dc66
dc66's Avatar
Started on the frame that will run around the perimeter of the floors.
I've chosen 30mm outside diameter tube because, well, that's what ive got tooling for in the tube benders.
ID:	216977   Click image for larger version
dc66 is offline   Reply With Quote
Old 13-11-2017, 08:58 PM   #25
dc66
dc66's Avatar
One side was about 10mm too long so I cut a piece out. I cut the bit with the weld out, giving me the chance to check the penetration
Happy with that
Old 13-11-2017, 09:48 PM   #26
dc66
dc66's Avatar
This gives you an idea of how wide the floor is going to be. There are going to be out-riggers to help support the floor. They will also give me decent mounting points for my seat frames
ID:	217001   Click image for larger version
Old 13-11-2017, 10:26 PM   #27
pablopassat
Looks like a good project Dave, I wish I was fit enough to do something similar, I have the skills but a smashed right hand makes the implementation difficult. I will be watching with interest. Good luck, not that you will need it
pablopassat is offline   Reply With Quote
Old 14-11-2017, 10:33 AM   #28
dc66
dc66's Avatar
Seems weird to be painting (badly) at this stage of the build, but I soon won't be able to get to these areas.
Oh and can someone explain to me why I thought I'd need to have the body bolt on? It just massively complicates the build!
Old 14-11-2017, 11:27 AM   #29
pablopassat
maybe because with Beetle based cars thats the normal accepted way. I can see no reason at all why you cant make the car a monocoque. The VW backbone lends itself quite well to that form of bodyshell, given that you wouldnt need to incorporate chassis legs at the front in the normal way to support engines and suspension. Decent outriggers from the central spine to support the floor and a sill incorporating an inner sill, outer sill and centre diaphragm should give you all the strength you need
Old 14-11-2017, 11:30 AM   #30
dc66
dc66's Avatar
That was my thoughts too......at 3am this morning!
