Body Sheet thickness - VW Forum - VZi, Europe's largest VW, community and sales
Old 24-01-2020, 09:49 PM   #1
fuzzybear1981
fuzzybear1981's Avatar
Trading feedback: (3)
Default Sheet thickness
Looking to buy some sheet metal to fabricate panels.... what’s recommended 1.0mm or 1.2mm
fuzzybear1981 is offline   Reply With Quote
Old 24-01-2020, 10:31 PM   #2
karisma
[IMG][/IMG]I think you will find stock thickness for body panels is 0.8mm.
I used 1 mm for my body panels on my fastback, as that was the only thing available You might find 1.2mm panel material a bit to stiff if you have to form any curved elements.
And i used 1.5mm galvanised material for the heater channels, but they only required folding at various 90 degree to form the box.
These 2 panels 1mm
karisma is offline   Reply With Quote
Old 25-01-2020, 07:51 AM   #3
psimitar
psimitar's Avatar
Stock panel thickness is 0.8mm. I use bright zinc plated sheet that comes in 0.9mm. It just adds an extra element of rust protection and means it can sit around in your shed for ages without rusting. Well rusting badly.
Any kind of compound curve will become increasingly more difficult to form the thicker the sheet you use.
madness is in the eye of the beholder
My '59 Beetle Resto Part I
My '59 Beetle Resto Part II
56 Oval Resto
psimitar is offline   Reply With Quote
Old 25-01-2020, 09:04 AM   #4
fuzzybear1981
I was under the impression you couldn’t mig weld zinc coat or is that galv I’m getting confused with?
Old 25-01-2020, 09:50 AM   #5
2much
I believe it is possible to weld both but welding galvanised steel is a "no no" because of the fumes given off being toxic - long time ago when I was told this as an apprentice so could be wrong!!
2much is offline   Reply With Quote
Old 25-01-2020, 10:22 AM   #6
karisma
Obviously when welding any material, proper safety protection is a must, including the appropriate welding respirator,
http://www.sperkoengineering.com/htm...Galvanized.pdf
https://www.eweld.com.au/blogs/news/...lvanised-steel
http://multimedia.3m.com/mws/media/1...tion-guide.pdf
Old 25-01-2020, 10:42 AM   #7
karisma
This fastback wing corner was hammer formed from 1.mm material
Inner wing view,
End view,
It would have been extremely difficult, if not impossible if the material was 1.2mm
Old 25-01-2020, 02:30 PM   #8
Big Al
Big Al's Avatar
Trading feedback: (7)
Yeah I learned this a few years ago. If you knew how much galv I welded in my youth before knowing this
I'm also uniquely qualified at welding underseal!
Big Als WorldOfRandom :)
https://www.youtube.com/channel/UCbf...jfnhBttYBAYkSQ
Big Al is offline   Reply With Quote
Old 25-01-2020, 10:38 PM   #9
Beetlebank
Beetlebank's Avatar
You will find 1.2mm quite hard going...
One cannot reason someone out of a position they did not reason themselves into.
Beetlebank is offline   Reply With Quote
Old 29-01-2020, 06:52 AM   #10
psimitar
psimitar's Avatar
Galvanised steel is zinc plated but just uses a different method to coat the steel IIRC.
And yes, wear a respirator otherwise you end up with welders flu like I did and took me a while to figure this out.
56 Oval Resto
