Area 1200:Performance Pages - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Old 21-11-2007, 07:47 PM   #11
DubKopfeYellow
DubKopfeYellow's Avatar
Mines quick enough for me sits at 70 (as long as theres no hills) so i'm happy, for now
DubKopfeYellow is offline   Reply With Quote
Old 22-11-2007, 12:48 AM   #12
Bugsy_Malone 666
Bugsy_Malone 666's Avatar
VZi Member Sponsor
Trading feedback: (7)
i got a 1200 engine, then i turned it 1496cc
the 1970 crank case takes bigger barrels and pistons but its at that point that you notice pistons/barrels/pushrods/deflector tins/headtins/heads/manifolds are all very different.
but happily I have fitted 1600 conrods/pistons/barrels/heads(SP) to a 1200 bottom end although i have yet to start it up!
what sort of limit RPM was is the crank good for?
im thinking of sticking in one of those 4500rpm governors in so i dont break the 1200 crank.
Its like being chased by an imploding star...
...One day I'll finish it all.
Bugsy_Malone 666 is offline   Reply With Quote
Old 22-11-2007, 11:39 AM   #13
HOT 1200
If you have fitted 1600 conrods, then the crank is not a 1200 crank.
13-1600 rods do not fit 1200 cranks...rods are too narrow.
BUT 1200 rods will fit a 13-1600 crank if you machine them, 1200 rods are too wide
1200 cranks are good to 5,000, mine often sees 5,500rpm.....they snap at anything over 6,000.......but flexing starts as low as 4,000rpm......
(if you flex them too much, metal fatique sets in and it may snap at tick over when you least expect it !!)
Bearing life on 1200 cranks often used above 4,500 is very short...expect less than 10,000 miles. The centre main wears on the sides but top to bottom remains untouched.......
If knew how to post pics, I have an excellent example.....
GaV
Anyone can make a big engine go fast!
But only a few know how to make a lil engine go faster!
1192cc 20.4 sec 1/4 mile on single solex 28 !
HOT 1200 is offline   Reply With Quote
Old 22-11-2007, 10:38 PM   #14
Bugsy_Malone 666
VZi Member Sponsor
im positive its a 1200.
the heads were 1200, the pushrods were somewhere around 1/2-1" shorter! there is definatly several mm less throw. also the air deflector tins were several fins shorter than normal.
its a unit which was remanufactured at some point im wondering if its been ground different.the 1200 conrods were shorter and obviously has smaller gudeon pins.
im going to fit a governed rotor arm which limits it to 4500rpm so i dont break it, but looking at the specs in the haynes i have the power band is lower than a 1300/1600 anyway so i shouldnt need to rev it so hard.
Old 23-11-2007, 11:43 AM   #15
HOT 1200
One way of telling what crank is fitted, is by looking at what exhaust fits the motor...
If you have a 13-1600 crank (69mm) then only a 13-1600 type exhaust will fit (because the engine is at least 10mm wider)
The lil 1200 crank (64mm stroke) is narrower, which is why all 1200 engines have to use a unique 1200 only exhaust.
My guess is its a 1200 motor with a big bore kit (83mm 1385cc kit??)
This is the only big bore kit currently available for 1200's which have unique pistons machined to accept the smaller 20mm wrist pins.
(all 13-1600 motors use 22mm wrist pins)
GaV
Old 23-11-2007, 07:49 PM   #16
Bugsy_Malone 666
VZi Member Sponsor
it `was` a 1200 when I got it, D code block, smaller conrods with smaller gudgeon pins, 1200 heads etc and 77mm pistons
but 1600 rods(from a fastback) fitted to the crank and being a later D code case 1600 pots fitted into the case, so then i fitted 1600 SP heads etc
one thing i did do was with the heads off on build up i used my vernier caliper to measure to stroke, which came out at 64mm
so basically im ending up with a 64mm crank 85.5mm pistons and stock length barrels resulting in slightly lower compression.
this could be a unique combination engine i have built
Old 27-11-2007, 12:16 PM   #17
HOT 1200
I scratching my head, not sure how you managed to use 85.5 pistons and barrels with a 64mm crank ???
I did some sums......worked out that would give you a deck heigh of at least .250th
Thats a compression ratio of less than 5.25:1
Im surprised it 'starts'..........
Unless you had the barrels shortend / machined down ?
GaV
Old 27-11-2007, 02:42 PM   #18
Bugsy_Malone 666
VZi Member Sponsor
GaV
I havent tried starting it yet
hmm nice low compression, just right for a long lifespan or a turbo!
or even TVO fuel
im just doing it for the giggle really, its built for the total sum of a gasket set all the rest are bits i had kicking about.
soon as i get the inlet manifold sorted we`ll see what happens
Old 28-11-2007, 03:29 PM   #19
HOT 1200
Good Luck, let us know how it goes....
Ive got my vintage HOT 1200 to build this year.......
So far.......
1967 small bore 1200 case and entire bottom end
ERSON V300 cam (vintage early 70's cam!!)
1300 twin port heads
Twin Dellorto FRD 34's (baby dells)
but also have a twin Dellorto DRLA 36 kit (depends how brave I feel)
Not sure about pistons...
cant decide between 1192cc or 1385cc big bore kit.
GaV
Old 29-11-2007, 12:13 PM   #20
Darcy
Darcy's Avatar
So far.......
GaV
Be brave Gav - the force is with you .............
KT ;)
Stock 1965 Bug & daily Polo hack
www.bootifuldubs.org
VW Enthusiasts Club, Norfolk
Darcy is offline   Reply With Quote
Tags
1200 performance, hot 1200
