My '59 Beetle Xmas Pressie Part II - Page 23 - VW Forum - VZi, Europe's largest VW, community and sales
Old 13-05-2019, 05:12 PM   #221
parkin10
parkin10's Avatar
Hey up
Now they have😀
parkin10 is offline   Reply With Quote
Old 14-05-2019, 10:33 AM   #222
psimitar
psimitar's Avatar
Cheers guys
Parkin10, I use Imgur to host my photos now. The earlier ones are still on photobucket so no more hosting there and I've not changed everything to Imgur as it's a massive task.
Do the lst few pages of photos work? I have started placing a 'h' at the end of the photos direct link so the forum knows to post as a huge thumbnail to try and save file size. Maybe that could be an issue depending on what you're using to view the forum.
madness is in the eye of the beholder
My '59 Beetle Resto Part I
My '59 Beetle Resto Part II
56 Oval Resto
psimitar is offline   Reply With Quote
Old 16-05-2019, 02:14 PM   #223
psimitar
psimitar's Avatar
Front inner arches all media blasted/paint strip disc. Area in red square of drivers needed a few patches as the blasting easily uncovers thin metal and this side hadn't been very well straightened after it's accident in the 60's.
There was still wrinkles in the dash to A-pillar corners that needed beating out. The thickness and type of paint the PO had used hid the damage well as did the bitumen paint in the underbonnet area.
Still, should just need a light skim of filler in the areas seen by the eye. Under the dash i'm not so worried about making smooth just cos you have to poke your head under there to see it and this will never be judged so is fine by me.
Should have them and undertank area in Epoxy 121 by end of the weekend
56 Oval Resto
Old 16-05-2019, 08:31 PM   #224
parkin10
parkin10's Avatar
Your pictures are fine it was on my end
I'm enjoying seeing your progress
Here's a quick pick of my recent doings
Old 17-05-2019, 10:02 AM   #225
psimitar
psimitar's Avatar
Ah, good old window corners. Beetles never rust there
56 Oval Resto
Old 26-05-2019, 12:34 PM   #226
psimitar
psimitar's Avatar
And got 2 coats of EM121 on.
Started skim coating the under bonnet areas from the old accident damage too.
Pics once it's all block sanded.
56 Oval Resto
Old 05-09-2019, 05:14 AM   #227
psimitar
psimitar's Avatar
A few photos showing the amount of filler work having to be done to the dash and under bonnet areas.
The old girl must have taken a hefty whallop to the front RHD side and then the body shop did a particularly crap job at straightening the metal.
As can be seen the LHD side has taken far less filler on the dash to get it straight and needed hardly any panel beating.
Slow progress just due to work, energy, a holiday and a few virus's.
Seems like I'll never get this done but I just keep chipping away at it.
56 Oval Resto
Old 24-01-2020, 10:05 AM   #228
psimitar
psimitar's Avatar
I managed to get the under bonnet area into paint before Xmas. These first two are the white sanding primer. It's ontop of more epoxy primer that was block sanded to 320. I chose white primer after doing spray outs on black, gray and white primers. The black was cool and deep but the white gave a kind of candy effect and allowed the curves to catch the light more interestingly.
The white was blocked down to 800.
And in colour
The dash is almost finished with the filler work and then can get epoxied ready for blocking
56 Oval Resto
Old 24-01-2020, 10:09 AM   #229
bean
looking good
I'm a slave to the South, there's a curse on this house
bean is offline   Reply With Quote
Old 24-01-2020, 11:32 AM   #230
Brownpantsracing
Brownpantsracing's Avatar
Trading feedback: (4)
Very nice.
Actually has a classic VW on the road again! Woo hoo. Oh hang on.. it's broken again. >:(
Brownpantsracing is offline   Reply With Quote
