General Moby's Diagrams Archive - VW Forum - VZi, Europe's largest VW, community and sales
Old 08-08-2012, 09:34 PM   #1
Mr.Whippy
Mr.Whippy's Avatar
Trading feedback: (3)
Default Moby's Diagrams Archive
Guys -
With reference to my earlier "Moby's Manual" thread - I thought I'd start a new thread specifically to re-publish any of those really useful diagrams & photos that Moby used so well to illustrate things.
If you have any saved on your machine, please add them below so they can be useful to everyone else.
I saved a few just in case they came in useful because I knew that Moby deleted them after a while (possibly to protect his work - who knows ?)
So here you go - (it's possible that some of these did not originally come from Moby but as I didn't make note when I saved them I can't be certain)
Starting the engine -
Beetle floorpan diagram -
Carb adjustment 1 -
More carb adjustment -
Gearbox input shaft seal extractor tool -
Replacing clutch return spring -
Link pin shim table -
VW Beetle tow bar (Peka) -
Hope you find them useful - please add your Moby pictures below.
(Many thanks to Moby - R.I.P.)
Mk 2 Scirocco 1600 GT new clutch kit
Mk 4 Golf front brake discs & pads new in box (288 mm)
- Collect for free - I need the space - PM me.
Mr.Whippy is offline   Reply With Quote
Old 08-08-2012, 09:35 PM   #2
Mr.Whippy
Mr.Whippy's Avatar
More Moby gems -
Beetle sunroof (steel type) -
Valve spring compressor tool -
Wiper motor lube -
Intermittent wipers on later beetles -
Starter motor bush removal & replacement -
Z bar rubber bush replacement -
Fitting axle boots (non split type) -
Fitting split type axle boots -
Fixing a squealing or stiff speedo -
Old 08-08-2012, 10:14 PM   #3
martin.2010
martin.2010's Avatar
rear hub
Kentish V Dub Klub
http://www.kvwk.co.uk/
HOT1200s
https://www.volkszone.com/VZi/showthread.php?t=407485
Originally Posted by paulatxntric View Post
...speed don't kill.....hitting things at speed kills and thats usually because people are driving like twats.....unfortunatly "twat cams" don't exist!
martin.2010 is offline   Reply With Quote
Old 08-08-2012, 10:28 PM   #4
Mr.Whippy
Mr.Whippy's Avatar
Repairing stripped M6 sump strainer studs with M6/M8 repair studs -
Old 09-08-2012, 08:14 AM   #5
42
42's Avatar
Thermostat and operating linkage:
Different operating rods available:
In that grey area between show and rat...
42 is offline   Reply With Quote
Old 09-08-2012, 08:27 AM   #6
paologray
I really must get out more
I've got a copy of how to fit a new Beetle karmann convertible roof cover, all models, including headlining, padding kit, wires, foams and top.
It's not Moby's work, but I'd be willing to scan it and add it to anything. Is that the kind of thing we're after?
paologray is offline   Reply With Quote
Old 09-08-2012, 11:43 AM   #7
martin.2010
headlight switch
oil sump plate
Kentish V Dub Klub
HOT1200s
Old 09-08-2012, 11:46 AM   #8
Rhodrich
Rhodrich's Avatar
Fitting brake shoes, and things to look for if they pull or judder.....
"Not poppy, nor mandragora, nor all the drowsy syrups of the world, shall ever medicine thee to that sweet sleep which thou owedst yesterday."
Rhodrich is offline   Reply With Quote
Old 09-08-2012, 10:00 PM   #9
squirt72
squirt72's Avatar
Name:  72-73 FUSEBOX.JPG
Size:  15.7 KB 72 bug fuseboard
Name:	Dyn to Alt (Ext).jpg
ID:	39739 dynamo to alternator with external regulator
ID:	39740 fan tin order
squirt72 is offline   Reply With Quote
Old 09-08-2012, 10:09 PM   #10
squirt72
squirt72's Avatar
Size:  26.4 KB type 2 air flaps & linkage
Name:	REV LIGHTS T1.JPG
ID:	39745 reverse light switch fitting
ID:	39746 balljoint location in torsion arms
ID:	39747 bug fuel tank breather pipes
